Results 1 to 13 of 13
    Aug 2003
    i hope some resident engineers can help out...
    i've seen a few DIY pages explaining how to do this -- i.e. run car, plug in DC to AC inverter, plug appliances. Just curious:
    -- Is it safe to do so, for extended periods of time(e.g. >24 hours)?
    -- how can you tell how many watts the car can produce at idle? Would revving the engine pump up the wattage? This is different from the rated hp(which refers to the mechanical power) of an engine right?
    -- most examples i see mention pretty lightweight devices: laptops, cell chargers, etc. Can you safely plug in appliances with motors(fans)? i think it's wishful thinking that you can plug in even a small A/C or ref?
    Aug 2004
    Ref, definitely not.
    The regular car-type inverters I've seen on the market aren't durable enough to run anything beyond a cellphone or laptop for extended periods of time. And it's a waste of gas... having an 80-140 hp engine powering a laptop charger when a simple 3-5 hp generator can run so much more on much less gas. (and even those small gasoline generators should not be used for such long periods of time)
    Pwede mong gawin yun bakit hindi?
    Ganyan ang ginagawa ko pag walang kuryente although madalang naman
    mawalan ng kuryente. I have a van w/c has a diesel engine so walang
    problema sa akin yung presyo ng gas. Kung gusto mong maglaptop at
    magcharge ng batt ng CP pwede ka bumili ng maliit ng inverter siguro mga
    100watts pwede na yun pang laptop at pangcharge ng batt ng CP mo kahit
    hindi mo buksan yung engine mo ng 1hour ewan ko lang kung kaya ng batt
    mo yung aking kasi kaya. Pwede ka pa bumili ng mas mataas ng inverter
    let's say mga 500 watts para paganahin yung ilang ilaw sa house nyo
    huwag lang yung ref...Pwede yun sa mga ilaw, tv, electricfan...Syempre
    tandaan mo na lang na mas mataas yung load eh mas mabilis ma-drain
    yung battery ng kotse mo so dapat paandarin mo yung engine mo...Kung
    itatap mo sa MAIN LINE ng house mo yung wire galing sa inverter make
    sure na ibaba mo yung switch para putol yung supply galing sa meralco
    para kung sakaling magkailaw eh hindi masisira yung inverter mo...
    Maraming nabibiling klase ng inverter, mayroon 100W, 500W, 1000W at
    may 2000W pa ata...Pero kung 1000W pataas eh huwag mo na i-plug sa
    cigarette jack mo yung inverter...I-modify mo na lang ito para pwede mong
    i-tap sa battery mo...Syempre gamit ka ng mas makapal na electric wire
    para doon para safe...Syempre pag matutulog na mas maganda kung patayin
    at disconnect mo na lang lahat para mas
    safe talaga pero pwde mo pa rin gamitin ng 24 hours yun kung gusto mo
    yun nga lang malakas yan sa gaso...Yung akin kasi pag ginagawa ko yun
    eh tinatanggal ko bago matulog...
    Aug 2004
    You can't run a car inverter for 24 hours because the puny electronics and wiring aren't built to run for that long. It's the same reason you can't run a cheap emergency generator bought at ACE hardware for very long periods of time... they're designed for light duty and emergency use... not for 24 hour use.
    And idling for hours isn't good for your car, and deep discharging a car battery is a good way to shorten its service life.
    Easiest for long brownouts is to have a portable generator that you turn on every few hours just to charge stuff with and run lights on. Safest is to buy a larger diesel generator.
    That's the best thing to do if you have enough money and if brownouts are
    regular everyday.
    Jan 2008
    mura lang naman yung china na generator.. mga 3k to 5k meron ka na.. 1 liter of gasoline per 1 hour depende sa load.. yung sa amin yung mumurahin lang 5k pa bili namin mga 2 years ago.. ok naman at nagamit namin nung mga nagdaang bagyo..
    yung 950 watts generator can run a sony 21 inch TV, 180 watts ground fan and 2 fluorescent lamps...
    Bro.,- I'd still recommend that you use a generator for this purpose.... That is what it was made for....
    10.9K:lotsocoffee:
    Oct 2009
    delikado ata yan bro. it was not made for that purpose.`
    Sep 2004
    you also have to consider the amperage (Amps) the inverter can support not just the wattage.
    Pero, years ago,- brownout sa amin the whole night (as scheduled),- nagpa-full tank ako ng sasakyan,- well-ventilated naman ang garahe namin. Sa loob kami ng sasakyan natulog (running engine and A/C)....
    10.9K:lotsocoffee:
    Quote Originally Posted by normanenoza View Post
    Well, I guess If you know the Amps...you should also know the Watts...
    Jan 2009
    for emergencies maybe you can do this. actually just hook up an inverter to your car battery (which you already disconnected from the car before doing so). then power up low power devices like your celphone charger. run a ref or aircon? dumb move. these require more power than your car or battery can deliver properly.
    one reason not to do this (run your car as generator) is efficiency. basic thermodynamics. the ICE of an automobile is the worst equipment you can use as generator. better a dedicated generator. sayang fuel (maybe you've heard of the ill effects brought about by pollution?).
    Jan 2010
    Quote Originally Posted by erick_214 View Post
    Yup, if you know the rating of a certain equipment you can compute for it's current carrying capabilities. For example a 500-watt heater for a single phase system: first divide 500 watts by 0.8(the normal power factor here in the Philippines) the result is 625 VA(volt-ampere), then divide this by 220 volts which is around 2.84 amperes.
using your car as emergency generator: safe ba?
