Results 1 to 18 of 18
    Aside from the expensive APC UPSes, what other UPS brands can you recommend?
    I just got 2 generic UPS from my local PC shop, brand: Elite. My problem with this UPS is it shuts down after a few minutes even if the battery can still last longer. I want my devices to stay ON as long as possible, but I cannot do it with this UPS.
    we are using several brands here at our office from those huges rackmount APC UPS3000 to the small APC UPS 500s, one thing I notice though among the brands that we're using here at the office, APC last longer as far as service/battery life is concerned, the others are a far second.
    I have used a number of LANTECH brand 600VA UPS units and they do a good job. I do notice that the batteries require replacement about every 1.5 to 2 years. The ones i have are around ten years old. Out of the six units, two have died (electronics failure) about a year ago and a month ago.
    I also bought a UPS from CDRKING (three months ago) but I have no idea how long the battery and the UPS will last. But it works fine so far.
    Jan 2008
    UPS are supposed to give you time to save your work..Not unless you are using extended batteries, its not intended to run long. If you really want uninterruptible power supply, better get a backup generator with auto start/stop and atomatic transfer switch.
    Ive been using APCs and Emerson/ Liebert and they are both good. What ive liked with APC is the availability of service, and battery they used is almost available everywhere. Quality of APC is good as industrial-grade UPS like GE, MGE(merlin gerin), Deltec, Delta. Other brands to consider-Powercom(PCM), AEC.
    If youre running a shop, better use larger UPS say 3kva with hot-swappable battery cartridge(ex APC SURT series). Its easy to maintain than one UPS per PC. Another tip is to check input voltage, higher tolerance the better. Avoid UPS with up to 230VAC input only, they are notorious for toasted varistors especially here in manila where voltage can surge up to 240-260V.
    Another good brand ive used is Tripp Lite, it served me well for 6yrs before i replaced batteries and untill now (on its 11th yr) its working.
    Jan 2008
    You can extend the operating time of a typical UPS on battery mode by replacing the original small 12volt battery with a large car or deep cycle battery. Downside is recharging a depleted battery will take a long time but if the power outage is not often (not daily), the original charging circuit should be enough.
    A few years back, I had a modified UPS capable of running over six hours. My brother had a larger battery and can run his PC for eight hours.
    Jan 2009
    ^ Did that with three 675VA Tripp-Lite more than a decade back coupled to a 2SM battery. That was a time when Metro Manila was having blackouts of 6-8 hours a day. We needed the PC for desktop publishing work.
    The problem with the UPS I bought is it shuts down after less than 5 minutes, even if the battery still have juice. I'm planning on replacing this with another brand. But I want to make sure that the replacement uses all the capacity of the battery before it shuts down.
    I have a APC BackUPS at home and it can do that but it's too expensive. the 1100kVa model costs more than 15K! I want one that costs less than 10K or better if less than 5K.
    I tried the Giant brand before... what a waste of money.
    Am not sticking to UPS...
    __________________
    bigbigcar.com Review: 2009 Honda Jazz
    You could try the UPS CDR-King.
    At least they're very afforable.
    Feb 2010
    Where can I buy a larger UPS that will run a PC for about 3 hrs?
    Quote Originally Posted by yoohoo View Post
    You can modify an existing UPS (that uses a 12 volt battery) and connect it to a large car battery or deep cycle battery for longer "backup" operating time.
    Feb 2010
    How is the modification done? Thanks.
    The modification is simple enough. You open up the UPS and remove the original battery. With wires of the same gauge as the one used in the UPS, you extend the existing battery wires and connect them to a couple of battery clamps (for best connection). Then attach the clamps to your car battery.
    Note: UPS devices use either 6 volt or 12 volt batteries. In this case, you want a UPS with a 12 volt battery.
    Do note that recharging will take longer than normal. Also car batteries do not last very long if you drain too much power.
    UPS devices also have a "beep" audio signal when it's operating in battery mode. You can disable this by simply removing the electronic speaker either by removing the soldering or by cutting one of the two connections to the speaker.
    BTW, another alternative is to buy a portable PC like a netbook PC with a six or nine cell battery. Typically these would last four to eight hours operating on battery power.
    Netbooks are not the fastest computers but they use less power than standard notebook computers.
    Feb 2010
    Many thanks
    Jun 2006
    If you can get 12V slow-drain gel batteries, the better.
    Quote Originally Posted by Horsepower View Post
    And where and how much would such cost?
Uninterruptible Power Supply
