Results 1 to 12 of 12
    CAUTION on the contact cleaner! madaming plastic parts dyan. lots of plastic parts don't react well to contact cleaner! when sprayed with contact cleaner some of plastics and polycarbonates will get "burnt", melt or even shatter.
    your regular Joy and water should do fine.
    ... strange.. my contact cleaner states on the etiketa.. safe for plastics and rubbers... yung pang-electronics..
    ah well.. just read the etiketa then.
    ^^and that's exactly why your contact cleaner manufacturer put that on the label dr.d, because there are contact cleaners out there that are not safe for plastics.
    Oct 2008
    so what brand of contact cleaner are you using po?
    so what brand of contact cleaner are you using po?[/QUOTE]
    forget... but the label is red...
    CRC CO-CONTACT CLEANER (blue can, made in belgium)
    stocks ko lang... meron naman siguro sa mga hardwares, almost sure, sa RAON.
    'yan ang gamit ko. subok na talaga...
    "safe for most rubbers, plastics, and coatings. TEST BEFORE USE ON RUBBER, SENSITIVE PLASTICS
    AND STRESSED PARTS."
    'yan eh kung matindi na ang kapit o tunigas na 'yung mga "lagkit- lagkit" (usually, mga mantika lang naman
    'yan o sebo na napabayaan na o hindi na nalinis ng matagal). try niyo rin muna detergent soap or dishwashing liquid.
    Oct 2008
    Quote Originally Posted by joemarski View Post
    thanks po sa reply
    thanks po sa reply
sticky door ng refrigerator
