Results 1 to 12 of 12
    Oct 2008
    hello po
    ask ko lang po. ano po pwede na remedyo dito. me times na mahirap buksan yong pinto ng ref? me times naman na ok lang parang normal.
    medyo bago pa naman yong ref, mga 1yr pa lang
    Quote Originally Posted by african888 View Post
    hello po
    baka marumi lang yung rubber and metal.. clean it po. try soap and water. if that don't work, try contact cleaner.
    hello po
    CAUTION on the contact cleaner! madaming plastic parts dyan. lots of plastic parts don't react well to contact cleaner! when sprayed with contact cleaner some of plastics and polycarbonates will get "burnt", melt or even shatter.
    your regular Joy and water should do fine.
    ... strange.. my contact cleaner states on the etiketa.. safe for plastics and rubbers... yung pang-electronics..
    ah well.. just read the etiketa then.
    ^^and that's exactly why your contact cleaner manufacturer put that on the label dr.d, because there are contact cleaners out there that are not safe for plastics.
    Baka may syrup natapon sa rubber seals. Just clean that magnetic rubber seals and the other side of the door where it makes contact. Wet sponge with detergent or baking soda(sodium bicarbonate) should be fine with rubber.
    Sep 2013
    TS, ref namin medyo mahirap din buksan pero oks lang para di sumingaw ang lamig. Buhusan mo ng kumukulong tubig sa ang buong rubber sa gilid lang ng ref ng 2x pero bago mo buhusan dapat tight sealed ang pinto. so lagyan mo ng packing tape ang gilid ng ref dapat tight close ito. iwan mo ng half an hr bago mo alisin ang tape. yan DIY ay effective sa mga ref na sumisingaw ang lamig not sure huh kung ma solve ito sa ang problem mo. at your risk lang ah
    use baby powder bro, effective daw ito
    Oct 2008
    so what brand of contact cleaner are you using po?
    so what brand of contact cleaner are you using po?[/QUOTE]
    forget... but the label is red...
    CRC CO-CONTACT CLEANER (blue can, made in belgium)
    stocks ko lang... meron naman siguro sa mga hardwares, almost sure, sa RAON.
    'yan ang gamit ko. subok na talaga...
    "safe for most rubbers, plastics, and coatings. TEST BEFORE USE ON RUBBER, SENSITIVE PLASTICS
    AND STRESSED PARTS."
    'yan eh kung matindi na ang kapit o tunigas na 'yung mga "lagkit- lagkit" (usually, mga mantika lang naman
    'yan o sebo na napabayaan na o hindi na nalinis ng matagal). try niyo rin muna detergent soap or dishwashing liquid.
    Oct 2008
    Quote Originally Posted by joemarski View Post
    thanks po sa reply
    thanks po sa reply
sticky door ng refrigerator
