Results 1,261 to 1,270 of 1687
July 24th, 2020 01:24 PM #1261
July 24th, 2020 02:24 PM #1262
pcb kasi nila sablay bro
ang weird lang, kasi design flaw tapos tagal ng issue ay di parin na address. as early as 2014 pa yun unang case ko nabasa yan sa pinas e
LG rin, design flaw na kahit naka unplug yun AC mo, nag generate parin motor pag umikot elesi while cleaning. ending fried board din. buti sana if lahat naglinis ng split type alam yan
Sent from my RMX2020 using Tapatalk
- Apr 2012
- 3,469
July 25th, 2020 09:24 AM #1263
- Apr 2012
- 3,469
July 25th, 2020 09:24 AM #1264
July 25th, 2020 09:47 AM #1265
July 25th, 2020 10:44 AM #1266
Check nyo rin ang add-ons. May base model and top of the line din kasi mga yan parang oto. If cooling lang kelangan mo then you won't need the nano-e mosquito killer whatever model of the same capacity that sells for a couple thousands more.
Sent from my SM-A605G using Tapatalk
- 54,200
July 25th, 2020 11:08 AM #1267
- Jun 2005
- 3,774
July 25th, 2020 12:07 PM #1268
- 54,200
July 25th, 2020 12:11 PM #1269
July 25th, 2020 12:23 PM #1270
It's likely they're not properly grounded.
All power supplies have built-in voltage suppression circuits.... it's the standard. However, these circuits only work when there's a path to ground to dissipate the energy. If there's none, this surge will look for the path of least resistance... going through fragile silicon transistors and ICs until it dissipates.
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
