Results 1,221 to 1,230 of 1687
June 1st, 2020 11:05 AM #1221
June 1st, 2020 11:10 AM #1222
Naku yan din ang sinabi sakin.. Ma-void daw ang warranty if mag-install ako ng lower HP sa recommended nila.. Not sure kung naloko na naman ako.. Hahahahahaha [emoji23] hirap talaga kapag walang alam.. 2.5HP tuloy nabili ko..
Napa-check ako photos.. 2 years na pala.. April 18, 2018 ko nabili.. from window-type nag-split-type inverter kami.. based sa electric bill namin, after 2 years balik puhunan na.. Pero di pa bawi.. From almost Php 10k na 12 hours lang ang gamit sa window type.. Php 2.5-4.5K na lang ang bill namin na 21 hours or minsan walang patayan tapos buong bahay na pwera kusina (buti na lang maliit din bahay namin [emoji28])..
June 1st, 2020 11:15 AM #1223
Nilinisan ko lang muna mga filter pero medyo madumi na rin yung coils.
Re:
Inverter vs non inverter, too soon to tell if durability will be the same, but in theory the compressor and other mechanical parts should last longer. The Jap brands are good. Just stay away from Samsung.
Our floor standing 4hp Sharp AC conked out after around 9 years. Instead of having it repaired, since it was old we replaced it with a 3 hp Daikin inverter. We are saving around 2-3 thousand pesos on electricity with the same usage. Both ACs were the recommended size by the technicians.
June 1st, 2020 11:22 AM #1224
- Jun 2005
- 3,774
June 1st, 2020 12:03 PM #1225For inverter, get the next higher available. The first 1-2 hours is not different from regular vs inverter aircon. Its on the 3rd hour you start getting the savings.
The faster the room cools, the faster you benefit from the inverter kasi maintenance of temperature na lang ang running cost nya which only uses about 30-40% electricity.
Sent from my MI MAX 2 using Tapatalk
June 1st, 2020 04:35 PM #1226
June 1st, 2020 04:37 PM #1227
- Jun 2005
- 3,774
June 1st, 2020 04:46 PM #1228
June 1st, 2020 05:01 PM #1229
- Mar 2010
- 2,275
June 1st, 2020 05:29 PM #1230Ang dapat linisin sa AC ay yung evaporator at condenser radiator, thru pressurised water pump.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
