Originally Posted by
oj88
Conventionally, solar power is used to charge a storage device (battery, in our case) and the battery in turn is used to light up the LED. Is this what you're trying to achieve? Or are you trying to light up the LED straight from a solar panel using indoor lighting?
Domestic indoor lighting is nowhere nearly as bright as sunlight so it's not used for anything other than say, turning on calculators or charge wristwatches. These things requires only a few microamps to work. However, a typical LED (not the ones used as indicators, but rather, those white ones that are suitable for illumination) requires a minimum of 50 to 100mA or more. As an example, a 1W LED requires around 330mA*3V.
A commercially available 3V/270mA solar panel is about the size of a pack of cigarettes. Although, it is rated as such, this is so at ideal conditions (ie. facing right smack at the sun, at noon, and in clear weather). To be able to produce the same amount of power indoors would require a larger panel. But then, you'll run into cost-benefit and practical issues with such approach.
Now, let's go back to being clear on what you want to achieve.
