Results 1 to 10 of 18
August 12th, 2009 10:19 AM #1
Just bought this incredible wireless router.
Have tested it with SUN 3G wireless and SmartBro (Canopy) and it works great!!! Can now share Internet anywhere.
Specifications:
Interface: USB 2.0 type A
Frequency: 2.4-2.48835GHz
Data Range: b/g/n
Security: WEP64/128bit. WPA,WPA2,AES
Drivers: WinXP/Vista 32/64
Access: up to 32 clients access
Protocol:TCP/IP,NAT,DHCP
Management: Windows based GUI
Certificatio: FCC, CE
August 12th, 2009 10:41 AM #4
Here's a screen shot of GUI based router config.
This USB N Router can also be used as simple Wireless LAN for your Desktop PC or old laptop without WIFI.
August 12th, 2009 11:00 AM #5
So how do you connect the WAN side for that USB router?... via WiFi from another router or does it use the connection from the notebook PC?
Can it operate independent of a PC (like plugging it to a USB power supply)?Last edited by ghosthunter; August 12th, 2009 at 11:03 AM.
August 12th, 2009 11:44 AM #7
You can actually choose WAN connection from the config menu. This Wireless N router is fully independent from your notebook WIFI LAN.
Sample below on how to configure with SUN 3G wireless. Clicking the WAN drop down selector button will show you all your WAN connectivity.
For SmartBro, no configuration is needed, WAN is automatically selected.
My Daughter was using it on their school group studies using single Sun 3G connection. So simple and straight forward configuration from simple security to more advanced security enabled.
August 12th, 2009 12:34 PM #9
yes, can you tell us where did you buy it and how much is it? I'm beginning to like this thing.
August 12th, 2009 12:35 PM #10
asteeg yan ah magkano yan baka bumili ako
nakasun broadband rin ako hehe
OT: sir ilang mbps yung sun nyo? akin kasi nung una nag 2mbps tapos ngayon nasa 1mbps nalang tapos bumababa pa minsan, bakit ganun?
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
