Results 1 to 9 of 9
    i just bought my daughter a samsung YP-T9 mp3 player recently. problem is, she cant upload music since di namin ma-install yung hardware for the portable player. we kept on getting error message which reads " problem installing hardware MTP Device....specified service does not exist as an installed service".
    accrdg sa samsung site, problem could be sa USB terminals o kaya wala sa OS ng aming computer. nakakapagtaka lang, lahat naman ng software na-install namin dito (i.e. digicam, CP, previous mp3's players) using USB ports were working fine.
    ano kaya problema mga tech gurus? ano ba tong MTP na to?, how can i install this sa aming system? TIA.
    Quote Originally Posted by OiC65 View Post
    Did you set the mp3 player as a pc device? This has to be done at the mp3 player itself. Actually, the device has to be on and set as a pc device.
    thanks bro........how to set the mp3 as a PC device? anyway, check ko sa settings ng mp3 player.
    I have an HCT (also Korean-made) mp3 player that wasn't being recognized by the pc until I looked at the mp3 player's mode and changed it from audio device to pc (or usb) device. After copying mp3's to it, I have to change the mode back to audio device so I can play the songs.
    Sep 2005
    Do you have the correct version of Windows Media Player?
    According to wiki, you need at least Media Player 10 for MTP to be supported by Windows XP (on Vista, MTP support is already built-in). If you have the correct version, you may want to try to re-install it, as it seems to be the solution to other MP3 players with MTP issues during installation.
    Also, remember to connect the YP-T9 directly to a USB port and not through a hub.
    HTH
    bump...
    actually, medyo short cut ang story ko. nakapag-upload ng mp3 ang anak ko before but nung try nya ulit, ayaw na.........so we try to re-install the software and hardware (portable player). software (Samsung Media Studio) was installed sucessfully but yung hardware ayaw na..........like I said kept getting error message.
    further check with samsung product support.......may nabasa akong something about like this.......
    After completing the file transmission, you must disconnect the cable in the following way:
    Double-click on the green arrow in the taskbar on the bottom right corner of the window. (Safely Remove Hardware icon)
    Select the USB device, and then press the [Stop] button.
    You will get a message indicating it is now safe to remove USB device. (Remove the USB cable)
    Warning: Removal of the USB device without following the above instructions will result in damage to the flash memory. Please follow these instructions everytime you remove the device from your computer.
    Unfortunately, my daughter failed to follow this instructions........so does it means na-damage na ang flash memory kaya di na ma-install yung hardware for portable player? if so, paano kaya ma-fix to?
    sensya na guys....
samsung mp3 player.......help!!
