Results 1 to 10 of 12
- Oct 2008
- 380
May 10th, 2015 11:08 AM #1hello po
ask ko lang po. ano po pwede na remedyo dito. me times na mahirap buksan yong pinto ng ref? me times naman na ok lang parang normal.
medyo bago pa naman yong ref, mga 1yr pa lang
- 54,299
May 10th, 2015 11:10 AM #2baka marumi lang yung rubber and metal.. clean it po. try soap and water. if that don't work, try contact cleaner.
May 10th, 2015 11:19 AM #3
CAUTION on the contact cleaner! madaming plastic parts dyan. lots of plastic parts don't react well to contact cleaner! when sprayed with contact cleaner some of plastics and polycarbonates will get "burnt", melt or even shatter.
your regular Joy and water should do fine.
- 54,299
May 10th, 2015 11:21 AM #4
May 10th, 2015 11:38 AM #5
^^and that's exactly why your contact cleaner manufacturer put that on the label dr.d, because there are contact cleaners out there that are not safe for plastics.
- Nov 2009
- 3,509
May 10th, 2015 12:37 PM #6Baka may syrup natapon sa rubber seals. Just clean that magnetic rubber seals and the other side of the door where it makes contact. Wet sponge with detergent or baking soda(sodium bicarbonate) should be fine with rubber.
May 10th, 2015 01:00 PM #7
TS, ref namin medyo mahirap din buksan pero oks lang para di sumingaw ang lamig. Buhusan mo ng kumukulong tubig sa ang buong rubber sa gilid lang ng ref ng 2x pero bago mo buhusan dapat tight sealed ang pinto. so lagyan mo ng packing tape ang gilid ng ref dapat tight close ito. iwan mo ng half an hr bago mo alisin ang tape. yan DIY ay effective sa mga ref na sumisingaw ang lamig not sure huh kung ma solve ito sa ang problem mo. at your risk lang ah
- Oct 2008
- 380
May 10th, 2015 01:49 PM #9
- 54,299
May 10th, 2015 03:07 PM #10- - - - - - - - - - - - - - - - - - - - - -
so what brand of contact cleaner are you using po?[/QUOTE]
forget... but the label is red...
VinFast VF 3
