Results 11 to 13 of 13
May 11th, 2020 01:33 PM #11
the one i have is old. binaklas ko na dati yun. i found the antenna to be atttached via SMA connector. so i bought an external high gain antenna..kaso ung cable nman problema..wag ko daw butasan sabi ni misis at bka mgkaproblema e hindi nila maitwag naman sa globe.
ideclare ko na lang na damage then itwag ko agad sa globe para mapilitan (sana) silang i-activate ung modem ko.
May 11th, 2020 01:45 PM #12
usually naman sa pinas mga residential subscriptions class C ip lang binibgay...non-routable. well at least sa mga smart and globe subsription namin dati sa bulacan. never had issues naman if WFH ako. mabagal lang talaga.
and globe support doesn't even know kung anong equipment iniinstall ng contractora nila. jot even the brand. ieescalate daw nila. kaya nabuwisit na rin ako.
ayaw nman padisconnect ni misis at stable daw globe sa amin vs PLDT.
May 11th, 2020 01:52 PM #13
look for those newer 802.11ac models from linksys/dlink. get one with high gain antennaes or at least replaceable ones.
but like the others are saying - check if your existing gateway device will work with it (it should in most cases)
i've been seeing those TENDA brand devices for sale in lazada and shoppee. check their reviews.
