Results 11 to 20 of 30
July 11th, 2007 12:10 AM #11
If the remote computer is being used or playing a game that is full screen, what will I see on my computer? The game or the desktop?
July 11th, 2007 12:20 AM #12
its a remote control, you're not opening a new session.
you will see whatever application is open on the remote computer.
you can also connect to view only to see if anybody is using the computer.
if somebody is using the computer and you connect to control,
magaagawan kayo sa mouse and keyboard. :DLast edited by roninblade; July 11th, 2007 at 12:23 AM.
July 11th, 2007 07:17 AM #13
So if the remote computer is currently playing an online game, when I view it, it will show the game on my screen? So pwede ko pala guluhin yung naglalaro :bwahaha:
July 11th, 2007 12:18 PM #14
July 11th, 2007 12:39 PM #15
if you can afford it, you can buy the single license of PCAnywhere. daling gamitin. but if you cannot, you can do windows remote control for this, BUT this does not work the same as PCAnywhere where you can see the actual remote controller is doing to your computer. WIndows Remote Control logs out the user, and allows the Remote Controller to login as Administrator (he should know what is the password of the Administrator na naka setup sa computer mo.)
what would you need to do is to open a port sa windows firewall, if you are not hiding behind a corporate firewall. normally, the TCP+UDP port 80 is utilized.
if you are hiding a corporate firewall, try to request assistance from your systems administrator to open this port up for you, using the same protocols, and allow incoming packets from your source I.P. (PC or another server...)
for VPN, you may need to do a port forwarding. medyo mahabang explaination. PM mo na lang ako kung kailangan mo pa ng mahaba-habang information.
same goes for going out from your PC to another PC.
hth.
July 11th, 2007 01:02 PM #17
afaik bro, hindi.... remote just means you are taking over the desktop or the computer as if you are controlling it, even though you are away from the computer.
ftp is a different scenario. its an exchange of files between two computers so that means, if you are behind a firewall, you have to allow FTP, and you have to use an FTP software (like WFTP) wherein one screen contains two different sets of computers. one is the remote and one is the host.
print sharing, is also not possible in remote.
July 11th, 2007 05:00 PM #18
In cases of HP, kahit naka-off yung state ng PC, pwede sya i-turn on thru Wake-on LAN options ng BIOS, and also dapat nakaplug yung power cord ng pc and nakakabit yung LAN cable. With the proper tools, you can now command your PC to power-up...so green compliant lahat kami sa ofc hehe!
Dati I am using "LogmeIn.com" wherein it requires you install it on the pc that you want to control, set the settings and voila, you can now remote, may security option din yun like you may want to power off your monitor whenever you remote control it, and also pwede file transfer at printer sharing.
With the vast securities that we are implementing at the office, we are using VPN to be at least connected dun sa ofc LAN...and by invoking RDC or mstsc, pwede na control office pc kahit saan (kaya wala akong ligtas )...and there's this option sa RDC wherein you may want to share your local resources like drives, printers and serial ports.
July 11th, 2007 05:23 PM #19
sa remote desktop ng Windows XP pwede ka mag file transfer, copy paste lang ok na.
Badtrip din to minsan, ung sa dati kong work ung pc na gamit ko server din. ayun ang daming nag reremote admin, minsan bigla na lang gagalaw ung mouse tapos mag oopen ng notepad tapos lalagay "peram muna ako sandali". hehehe
ung vnc saka radmin naman gamit ng boss namin dito sa work ko para mamonitor kung may ginagawa kaming kalokohan. hehehe. pero diba dapat bawal un? hehe
DIY to death!
- Jan 2003
- 451
July 11th, 2007 05:43 PM #20
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
