Results 1 to 16 of 16
    What's a good brand and model? Para pwede ba mag print from smart phone ng mga emails, etc.
    Am using hp3525, print, scan, copy. Does what its supposed to do. Can print wirelessly to it from tablet, phone, laptop. Even if youre outside its wifi network. Cheaper ink as well.
    I am using HP bro, at home. Forgot the model- but this comes with scanner...
    Everything's tied to our wireless router.
    Two desktops on wireless, five laptops on wireless,- no issue.
    I have not tried printing from a handphone, though....
    28.3K _/_/_/_/_/:santa:_/_/_/_/_/
    Jan 2009
    I have an HP P1102w (monochrome) laser printer. Supports printing from iOS devices, among others.
    i don't use a wireless printer per se.
    but bought a router with print server, and attach the printer to the print server.
    another option is to just attach the printer to the router, share it via network and print from the WLAN.
    Jan 2009
    Just to add, if you have iOS devices and you wish to print from them, you should look for a printer or printer server that supports AirPrint.
    Or you'll go insane.
    yup.... although you can have that worked around on, by synching files from the iOS device to a PC using dropbox or one drive, and print it from there.
    Thanks. So HP is the way to go. Wala ba ibang brand? Are newer HP models uses the same ink cartridge across models? Or should it be another basis when buying a printer? Ano model yun murang original ink cartridge.
    yes, they are consistent na on across models.
    however, if you can afford a laser one, yun na kunin mo... mas matipid sya per page.
    speaking of printers, ok ba ang aftermarket CISS sa printers?
    Jul 2006
    I am using Brother MFC-J625DW that supports AirPrint/Scanner/Printer/Auto Loading Feeder/FAX for 4 years na. So far no problem whatsoever.
    I have installed a 3rd party ink cartridge and it can print 1 to sawa hehehe.
    Sep 2014
    Im using Samsung Wireless Laser Printer. it can print from iPhone, iPad, Macbook, My relative's androids and Windows laptop.
    Good! Hanap ako Sa weekend? Saan maganda bumili? Yun Maraming choices
    Sep 2009
    If you need wireless, laser, scan/print/copy, highly recommend Brother DCP-2540DW. Highly rated in reviews.
    Got one in Greenhills, promo less P2k right now.
    I had the HP 3510 printer/scanner with wifi. It already has relatively cheap cartridges (HP Ink Advantage, around 400 per cartridge, different cartridge for black and colored) but it's still quite costly - I replaced black cartridges every other month, and colored cartridges every 3-4 months.
    Recently replaced it with Epson L355 continuous ink. My siblings print their college papers in full color, halos wala pang bawas sa ink tank. Baka graduate na sila di pa ubos yung ink. [emoji12]
    Same wifi functionality and connectivity, printer and scanner na rin.
Wireless printer.
