Results 1 to 10 of 10
Threaded View
    Jul 2003
    I bought and installed a 500gb samsung HDD as my 2nd HDD. my 1st HDD is western digital.
    I believe it is a SATAII drive and my motherboard (AliveMF7g-HD720) supports SATA II. The samsung HDD can be detected by the system and i was able to partion, format and put files into it.
    the problem is that whenever i restart my pc, booting takes forever, windows explorer hangs and all the files i put in the 2nd HDD disappears. after doing reformatting and seemingly able to fix the problem, it happen again every reboot.
    then i removed the 2nd HDD and everything is normal again.
    what is the problem here?
    should i just buy an enclosure and use the 2nd HDD as an external hard drive since its purpose is for back up? if so, are CDR king enclosures OK?
Problem with my 2nd SATA HDD - should I just use an enclosure
