Results 1 to 10 of 10
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 14th, 2010 12:11 AM #1I bought and installed a 500gb samsung HDD as my 2nd HDD. my 1st HDD is western digital.
I believe it is a SATAII drive and my motherboard (AliveMF7g-HD720) supports SATA II. The samsung HDD can be detected by the system and i was able to partion, format and put files into it.
the problem is that whenever i restart my pc, booting takes forever, windows explorer hangs and all the files i put in the 2nd HDD disappears. after doing reformatting and seemingly able to fix the problem, it happen again every reboot.
then i removed the 2nd HDD and everything is normal again.
what is the problem here?
should i just buy an enclosure and use the 2nd HDD as an external hard drive since its purpose is for back up? if so, are CDR king enclosures OK?Last edited by fourtheboys96; January 14th, 2010 at 12:14 AM.
January 14th, 2010 09:37 AM #2
Why not return the Samsung and get another WD HDD as a replacement?
Using a USB to connect your HDD wil make it run like a snail when it could perform much faster.
- Jul 2003
- 2,267
January 14th, 2010 10:00 AM #3i don't know if i can return something i bought that is not defective.
January 14th, 2010 12:45 PM #5
January 14th, 2010 01:04 PM #6
January 14th, 2010 04:39 PM #7
He can try exchanging the Samsung for a WD. But, I don't know if that will make any difference. I've never seen too many differences among different hard drive brands.
I'm inclined to think it's a bios setting. But, let's see him exchange the drive first and see if it works.
- Jul 2003
- 2,267
February 2nd, 2010 10:18 AM #8Ok guys this is what I've done since my last post.
I searched for an enclosure but found none that can support up to 500gb. What I bought in CDR King was a docking station with USB and eSATA ports. I was able to copy my files into the hard drive. But after re-starting the PC, the problem occurred again. Then suddently, the hard drive cannot be detected via the docking station nor the motherboard.
I returned it and he store replaced the hard drive (same model) immediately.
I installed the new HDD in the mobo and it works perfectly.
so many late nights wasted waiting trying to figure out the problem. positive thing is that i learned some thing tinkering with the PC.
February 3rd, 2010 03:28 AM #9
since newly purchased yung hdd, you should've had it replaced agad at the first sign of trouble.
- Jul 2003
- 2,267
February 3rd, 2010 07:50 AM #10
Thank you!
