Results 1 to 7 of 7
    If the problem persis there must be something wrong with the linksys router. Same thing happened to me, and I had my router check and there is something wrong with it. since its within warranty, they replaced it.
    hmmm, could it be the motorola cable internet? matagal na ba sayo to? kung nade detect ng laptop ung router but cannot browse the internet, then baka sa settings lang ng router, try to tinker with the configurations by logging in as admin sa router, make sure you use the same protocols for the 2 computers. I remember merong setting ang Linksys router na disconnect if Idle options, lagay mo lang puro '9' para maximum time.
    pag ayaw pa din, maybe you can also check the modem for overheating problems, i had bad experiences with motorola dsl modems, mabilis uminit, pag uminit, bumabagal or nawawala ang connection. HTH
    the modem and the routers are brand new...
    actually..walang problema sa connection..im averaging 2-3mbps download and can sometimes go to my max of 5mbps.
    problem lang is kapag pinatay ko na computer or na idle ng ilang oras..nawawala yung connection tapos i have to manually reboot both the modem and router =(
problem with internet: keeps on needing to reboot modem
