Results 1 to 10 of 17
June 12th, 2006 06:48 PM #1
Guys,
With the high electric costs, we are contemplating on getting this... effective ba ito? The details are below
POWERSTAR
An Electrical Device that helps reduce electrical consumption of inductive or motorized home/appliances such as Air Conditioner, Electric Fan, Water Pump, Washing Machine, etc. The Power Star is a handy version of Power Factor Corrector designed conveniently for home and office use, where the device can be easily plugged to any electrical outlet. A Power Factor Corrector is a device that recycles partial of the electrical waste generated by the said inductive equipment. This recycled electrical power is then feed back to the same circuit at the same time thus reducing the need for fresh electrical power. It is recommended to turn off the device when no inductive equipment is being used. Do not pull out the device from socket it is ON. Avoid turning it OFF when there are still inductive equipment ON. Avoid touching the plug of the device after disconnecting it from the outlet. Plug the device in a stable outlet not on an extension outlet.
Recommended Minimum Load:
* 15 Amperes Initial Load
* 3,300 Watts
* 250 kw/hr Average Monthly Electrical Consumption
Energy Saving Technique: The Power Star saves electricity
Special Features :
* Energy saving from minimum 20% to maximum 35%
* Easy installation & function
* Absorb and reuse the ineffective electricity
* Surge protection function
* Reduces the power consumption of appliances and equipment
Advantages:
* Installed in any unoccupied convenience outlet or an extended line
* Flickering & noise free
* Small in size
Testing Results: SGS Taiwan Lt. Laboratory Testing Center
Test Report Date: December 5, 2000
Power Star Application
* Residential, Commercial, Shopping Arcade, Hotel, Industrial Facilities, Factory, Government Building School, University, Indoor Sports Center, Park
Specification : Input Voltage: 1 Phase 2 wires 100 –260V.
Frequency: 50Hz/60Hz
* IF YOU ARE PLANNING FOR A LONG VACATION, WE ADVICE YOU TO UNPLUGGED POWERSTAR *
Feedback naman sa mga gumagamit at naka gamit na.
Thanks!
June 12th, 2006 08:44 PM #2
Yes,... it is very effective....
........ in emptying your wallet of your cash.
June 12th, 2006 11:35 PM #4
Yang ang Khaos Super Turbo Charger para sa bahay! hehehe.
Kung nagpauto ka sa KSTC sa kotse mo, isagad mo na!
June 13th, 2006 07:25 AM #6
i forgot how that works pero we got to figure it out nung highschool pa, nung bago yan...
ripoff, to summarize. heheh.
- 10,620
June 13th, 2006 10:19 AM #9
kala ko ba may konting effect but only on appliances with motors like electric fans and a/c? or false testimonies lang un hehe
June 13th, 2006 01:11 PM #10
May thread tayo neto, Yebo explained how it works... like what BB said, it affects motor-powered appliances more. (washers, refs, ac etc).
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
