Results 1 to 14 of 14
    Mar 2004
    Need suggestion in building Gaming PC. Something between mid range and high end. Also, what type of TV would be good for gaming? What are the specs that we should look at when considering a gaming TV? Size would be 55" to 65".
    Sep 2016
    Budget sir? Do you prefer AMD or Intel?
    Tv specs should have at least refresh rate at 120Hz....
    You can search gaming cpu you preferred and check the hardwares then you can start from their... like sa Asus Rog, HP omen, MSI infinite and ASUS predator are good reference...
    Good luck sid!
    Mar 2004
    Something between mid range and high end ... as mentioned above ... AMD or Intel is fine ... But the trend these days is AMD ...
    Sep 2016
    Maybe you would like this setup. Ito balak kong buuin though wala pa budget.
    cpu: AMD Ryzen 5 3600
    motherboard: MSI B450M Mortar Max
    ram: GSkill Ripjaws V 16GB 2x8GB 3200Mhz F4-3200C16D-16GVKB
    ssd: Adata XPG SX8200 Pro 256GB NVME m.2
    hdd, WDC Blue 1TB
    gpu: MSI GTX 1660 Ti Gaming X 6G Twin Frozr
    psu: Seasonic Focus Gold 550FM 80+ Gold
    case: Tecware M3 MATX Tempered Glass (Black)
    Not sure about the gaming TVs though, maybe the likes from Samsung or LG are good. Also, you might want to change the gpu to a stronger one (RTX maybe?) if you are going to play on a higher resolution (4K).
    Feb 2005
    hdd, WDC Blue 1TB
    sir, magkano abutin yang ganyang set up?
    Apr 2014
    Stay away from msi b450m.
    Yung bios chip is mababang capacity lang. Yung mga future bios upgrades na kelangan to run ryzen 3rd gen correctly is most likely di na kasya.
    Sep 2016
    Quote Originally Posted by box_type View Post
    50k sir tops.
    Quote Originally Posted by chronicle View Post
    Is it only for MSI or all B450M boards?
    Apr 2014
    50k sir tops.
    Msi lang
    I upgraded from an AMD FX-8350 to an Intel i5-8600 not too long ago. That plus 16 GB DDR4 2666 RAM, WD Blue M2 512GB SSD, new copy of Windows 10.
    I'm also still using my existing parts: 6GB GTX 1060, 2TB and 500GB hard drives, gaming keyboard n mouse......
    Once I get my fill of the STALKER and Fallout 4 universe, I'll upgrade from the GTX 1060 to the RTX 2060 line.
    Jun 2015
    Currently trying to resurrect my socket AM3 mobo that keeps throwing BSODs. Found 2 bloated capacitors kaya pala unstable ang voltage reading ng RAM pag sinilip sa BIOS menu. Ordered replacement capacitors overseas through Shopee. Pag pumalpak, well, the board is pretty much at the end of its life anyway.
    Sadly, wala pang budget for a Ryzen build.
    Sent from my Nokia 6.1 using Tapatalk
    hdd, WDC Blue 1TB
    Planning to get this build. Got a qoute around 50k. Did you buy it already?
    Oct 2021
    What kind of games are you planning to play? Kung competitive gaming like MOBA, MMORPG, or FPS games, I do not recommend using a TV kasi malaki delay nyan in terms of response time compared sa gaming monitors
    Sent from my HD1900 using Tsikot Forums mobile app
    Jan 2010
    hdd, WDC Blue 1TB
    This was probably just under 40k pre-pandemic. These days, this will probably go upwards of 60k. The 1660 Ti was 14k in 2019, today it's 26k. Supply chain disruptions, global chip shortage, the rise of cryptomining, and, of course, the pandemic, have all contributed to the most bloated computer prices since the 80's.
Pls suggest gaming PC build and TV specs for gaming.
