Originally Posted by
niky
I've never heard of that one... I just use AVG and am very careful about what I open.
There are many variants of the virus that kills regedit and taskman, most are non-fatal but pretty annoying. They 're usually found via autorun on flashdrives shared with other users.
Download the taskmanager enabler, then the regedit enabler, then run them. Once you've run the taskmanager enabler, you can kill any virus-like processes... usually rundlls, that are running... then wipe your registry clean (there are instructions online on which command line to fix for the regedit). Run the anti-virus again (but if it didn't catch it before, it probably still won't catch it... in which case, try one with a bigger library, like AVG)... this still isn't a perfect solution... the perfect solution is to start the anti-virus booted from a clean copy of windows... but it'll do for now.
Also, go into your systems settings (it's also in the registry) and turn off autorun. Autorun is a completely useless Piece of S*** that allows simple registry-hacking viruses like this to proliferate.
