Results 1 to 9 of 9
- Feb 2008
- 898
July 3rd, 2009 02:06 PM #1I have a software which requires to edit the registry under windows (by the way my OS is XP Pro). But, every time it attempt to do so, I receive this message: "Registry editing has been disabled by your administrator." I own the computer so I am the supposed administrator, right? Please help
- Dec 2007
- 142
July 3rd, 2009 02:59 PM #2Go to START > RUN
Type: gpedit.msc and click OK
On the left pane, go to ADMINISTRATIVE TEMPLATES > SYSTEM
On the right pane, look for the PREVENT ACCESS TO REGISTRY EDITING TOOLS entry, right click on it and click PROPERTIES
Set it to either NOT CONFIGURED or DISABLED
click OK and check if registry editing is now enabled
July 5th, 2009 12:23 PM #3
You have a virus. Registry editing is only disabled when you are the only user when a virus tampers with your registry files. Best to get a good anti-virus and clean it out. You'll need to start from a safe boot-up disk.
If you can't open task manager b y pressing ctrl-alt-del, then it's a sure bet that's what it is.
You can also download this: http://www.softpedia.com/get/Tweak/S...-Regedit.shtml
It's a small app that restores reg-edit. You might also want to get its sister app that restores task manager...
- Feb 2008
- 898
July 6th, 2009 08:55 AM #4I think you are right, it must be a virus. I can not open the task manager with ctrl-alt-del method. BTW, my anti virus is ESET NOD32, whose virus definition is up to date. Is this not a good antivirus application? Since I have no time yet, is this kind of virus fatal to my PC or not?
July 6th, 2009 09:24 AM #5
I've never heard of that one... I just use AVG and am very careful about what I open.
There are many variants of the virus that kills regedit and taskman, most are non-fatal but pretty annoying. They 're usually found via autorun on flashdrives shared with other users.
Download the taskmanager enabler, then the regedit enabler, then run them. Once you've run the taskmanager enabler, you can kill any virus-like processes... usually rundlls, that are running... then wipe your registry clean (there are instructions online on which command line to fix for the regedit). Run the anti-virus again (but if it didn't catch it before, it probably still won't catch it... in which case, try one with a bigger library, like AVG)... this still isn't a perfect solution... the perfect solution is to start the anti-virus booted from a clean copy of windows... but it'll do for now.
Also, go into your systems settings (it's also in the registry) and turn off autorun. Autorun is a completely useless Piece of S*** that allows simple registry-hacking viruses like this to proliferate.
- Feb 2008
- 898
July 6th, 2009 10:21 AM #6
July 6th, 2009 10:53 AM #7
Just search for it via google... the author is the same as the author of restore regedit.
Good luck!
July 6th, 2009 11:57 PM #8
there's a utility called RRT. please search and scan with antivirus. sad to say, your troubles might not end in the system modifications made by the virus. maybe it's still in there.
July 7th, 2009 02:19 AM #9
replace your antivirus na din... the top 3 free (for non-commercial use) at the moment are Avast, Avira, and AVGFree.
