Results 1 to 11 of 11
    Nakakakita ako nagbebenta ng modem sa sulit, pwede ko ba gamitin 2 modems sa isang dsl line? I mean instead na router meron dalawamg modem sa magka ibang rooms...then sabay mag connect?
    Edit: PLDT hinde post...*auto correct*
    Sent from my iPad using Tapatalk 2
    May 2011
    what's your purpose?
    kung mahina wifi signal, buy a repeater instead.
    just curious... kung pwede///
    Jun 2004
    alam ko pwede 2 router pero mapuputol yun isa parati dito.
    dahil ang pagkakaalam ko, isa lang ang IP add ng pldt na binibigay per account, unless yun plan mo yun multi IP add
    one dsl line in two routers? parang di ata pwede. magaagawan ng IP address yan dahil your provider will only provide you with one dynamic address.
    extend mo na lang yung wifi mo.
    but if you would be using two dsl lines, in one router, pwede...
    di pwede bro shadow parehong IP address niyan yung isa lang din ang gagana
    Sep 2012
    Hindi pwede sir ang dalawang modem... You only need one
    Kung gusto mo ma extend yung range ng router mo pwede naman kung bibili ka ng dedicated wireless bridge or another router that supports wireless bridge. I extend lang nun signal ng primary router mo.
    Pag may time mamaya bigyan kita idea ng mga routers na may wireless bridge support na mura lang
    Jan 2009
    It will not work.
    The DSL modem talks to the DSLAM in a point-to-point manner. Adding a second modem on the same line will interfere with the first connection and you'll end up with both modems unable to connect.
    Thanks, curious lang ako Kung pwede, I don't have problem with wifi range...
    But sige ano yun router na meron bridge na mura?
    Sep 2012
    Ito na lang kuhanin mo para mas less headache for you pagdating sa configuration and at least dedicated access point pa and currently at 1,588
    Edimax EW-7438RPn N300 Universal Wi-Fi Extender | VillMan Computers
    Ito naman yung ibang kasama nya kung type mo na ibang brand
    Access Points | VillMan Computers
    Good thing that they opted to sell these na. Sa router kasi na may AP and wireless bridge support usual na sakit ng ulo is compatibility and configuration setup
    ^^ ganda nya ah......
PLDT dsl modem - two modems on one line?
