Results 1 to 10 of 11
July 17th, 2013 11:05 AM #1
Nakakakita ako nagbebenta ng modem sa sulit, pwede ko ba gamitin 2 modems sa isang dsl line? I mean instead na router meron dalawamg modem sa magka ibang rooms...then sabay mag connect?
Edit: PLDT hinde post...*auto correct*
Sent from my iPad using Tapatalk 2
July 17th, 2013 11:37 AM #4
alam ko pwede 2 router pero mapuputol yun isa parati dito.
dahil ang pagkakaalam ko, isa lang ang IP add ng pldt na binibigay per account, unless yun plan mo yun multi IP add
July 17th, 2013 11:46 AM #5
one dsl line in two routers? parang di ata pwede. magaagawan ng IP address yan dahil your provider will only provide you with one dynamic address.
extend mo na lang yung wifi mo.
but if you would be using two dsl lines, in one router, pwede...
July 17th, 2013 01:07 PM #6
di pwede bro shadow parehong IP address niyan yung isa lang din ang gagana
July 17th, 2013 03:04 PM #7
Hindi pwede sir ang dalawang modem... You only need one
Kung gusto mo ma extend yung range ng router mo pwede naman kung bibili ka ng dedicated wireless bridge or another router that supports wireless bridge. I extend lang nun signal ng primary router mo.
Pag may time mamaya bigyan kita idea ng mga routers na may wireless bridge support na mura lang
July 17th, 2013 03:42 PM #8
It will not work.
The DSL modem talks to the DSLAM in a point-to-point manner. Adding a second modem on the same line will interfere with the first connection and you'll end up with both modems unable to connect.
July 17th, 2013 04:03 PM #9
Thanks, curious lang ako Kung pwede, I don't have problem with wifi range...
But sige ano yun router na meron bridge na mura?
July 17th, 2013 04:41 PM #10
Ito na lang kuhanin mo para mas less headache for you pagdating sa configuration and at least dedicated access point pa and currently at 1,588
Edimax EW-7438RPn N300 Universal Wi-Fi Extender | VillMan Computers
Ito naman yung ibang kasama nya kung type mo na ibang brand
Access Points | VillMan Computers
Good thing that they opted to sell these na. Sa router kasi na may AP and wireless bridge support usual na sakit ng ulo is compatibility and configuration setup
Xiaomi E-Car
