Results 21 to 30 of 36
May 21st, 2015 06:12 PM #22
parang sa globe towers yan sa pioneer.... ang lalim ng basement parking.....
parang sa globe towers yan sa pioneer.... ang lalim ng basement parking..... if i remember it right, nagpark ata ako dun around 7 levels down.... took me around 15 - 20 minutes to reach ground level.
- Jul 2010
- 844
May 22nd, 2015 05:20 AM #24
May 24th, 2015 12:08 AM #25
June 5th, 2015 01:19 AM #26
Hi to all,
Ano bang condos ang affected ng fault?
I was looking if Eastwood City is affected and mukhang hindi naman?
Or its proximity to blue ridge & white plains make it susceptible to big damage pag more than 7.2?
Hi to all,
June 5th, 2015 09:22 AM #27
June 5th, 2015 09:35 AM #28
This site is genius, you can just type your address and it will show your site's distance from the fault line.
Project Tremors | InstigatorsLast edited by shadow; June 5th, 2015 at 09:39 AM.
June 5th, 2015 10:31 AM #29
not clear ang question mo sa 1st paragraph pero kung ang tanong ba anong distance ang safe sa structure from fault line to structure? acct'g to phivolcs 5 meters away from fault line is already safe. I'm not an engineer here but would a structures be safer nearest to the fault line compared to xx meters away? a similar concept when an object drops in a pool. do you notice how strong the wave is from stone to farthest wave???
June 5th, 2015 11:07 AM #30
My opinion is, unless you are squarely on top of the fault line, adherence to building codes and standards will matter more whenter you're 15meters, or 15 kms away from the fault line.
* Shadow, oks yung link ah. From what i saw, my family has a lot that is right next to a fault line.Last edited by vinj; June 5th, 2015 at 11:15 AM.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
