as i unchecked the auto restart button hindi na uli pa siya ngrerestart hehe bkit kaya?
pero nakita ko sa system 256 lng nadedetect na ram. 512 kc ito. baka sira yung isa? tama ba?
waaaah it happend na naman. hindi nga nagrestart ng shutdown lang. pero the blue screen fashed din lang.
tapos nung nag turn on ako
E:\WINDOWS\Minidump\Mini042508-02.dmp
E:\DOCUME~1\LOCALS~1\Temp\WER1.tmp.dir00\sysdata.x ml
eto daw yung log file na may error details. di naman maopen
halos sure ako na ram yan or yung slot ng ram. To troubleshoot, remove 1 stick of ram. kung di na mag restart nahanap mo na ang problema.
TS pasingit...
patulong din guys, pag nagrun ako ng CMD Prompt, nagre-restart desktop ko, otherwise ok naman sya. bakit kaya?
problema kasi pag niload ko CounterStrike, nagre-restart din e kasi gumagamit at ng CMD Prompt yun.
salamat!
Maraming causes ang PC restarts:
- kaunti ang memory (upgrade to higher memory) mababang memory, kaunting load, parang taxi...hindi puwedenng animan
- masyadong maraming naka-save sa computer mo (tanggalin ang hindi kailangan) the higher the number, the more memory it takes!
- mahinang klaseng computer (buy a reputable computer)
- homemade computer (dapat sa computer geek ka nagpa-assemble)
- and the most culprit of them all...VIRUS! (iwasan magbukas ng hindi kilalang email at huwag magpunta sa **** website)
sir, nakakapasok ka pa ba mismong windows, kung di ka na nakakarating dun, malamang sira na OS mo.reformat mo na yan mas lalong mawawala files mo pag nagdebug na mismo ang OS.
memory related din yan.try mo muna mag reset ng memory,at CMOS.kung hindi pwedeng sira na RAM mo.IMHO.
it happened to me also. I noticed na ung hard disk cable eh matigas na. I changed it, ok na.
It's most likely RAM but for me, I had the same thing, My friend just searched on the websites to fix it, and he found a file to download to fix it. After a reboot and some couple hours of waiting for everything in the computer to be checked it worked. I'm not exactly sure what the name of the file is, but it had to be burned on a cd to work. Hope your pc gets fixed!
Its the physical memory dump. Its the blue screen that suddenly pops-up, halting the computer. It is called the "blue screen of death". I'm having the same problem too with my laptop and trying to resolve the issue with known registry errors using some softwares like uniblue power suite and errordoctor2008. Some issues relating to this problem are a lot programs/apps running at the same time, thus physical memory fails. If you are curious to see what the blue screen text displays (if you are expecting it to happen again), you have to enable it. To do this:
1. right click My Computer and select Properties from the drop down menu
2. click the Advanced tab
3. on Startup and Recovery section, click Settings
4. on System Failure section, uncheck Automatically restart box
5. click ok
issues relating to this problem: http://www.techspot.com/vb/topic17836.html
Will post if I come up with the solution or when my laptop becomes stable. So far di pa naman nag-re-appear (running aps: winamp, firefox, uniblue guard, uniblue spyeraser) after running the uniblue power suite and uninstalling temporarily AVG. Will try using errordoctor2008 since it says it can fix the blue screen of death http://www.errordoctor.com/index.php?hop=software30
I finally decided to reformat my laptop restoring its normal performance. I guess the main cause of restarting was viruses, spywares controlling my comp. Okey na ulit sya ngayon. Di ko na muna nilagyan ng registry cleaner app, If you are unsure with changes on your registry, do not use any cleaner, otherwise maco-corrupt yun. Di rin ma-repair ng Error Doctor yung blue screen issues.
* vanqrvr, malakas pa ba batt pack ng laptop mo? If it doesn't and AC na lang ginagamit mo for your laptop, unplug the DC adapter from your laptop after shutting it down or kung di mo naman ginagamit. Saka mo lang ire-plug kung gagamitin mo na laptop mo. Ganyan din sa kin nangyari. Yung weak battery pack na di na nagre-recharge ang culprit.
im the starter of this thread balik na naman same problem. i disabled the auto restart, sa blue screen i got this Bad_pool_list. minsan pfn_list_corrupt. minsan irql_not_less_or_equal
