Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Aug 2004
    SMART Communications Inc. may be blocking calls coming from the networks of Gokongwei-owned Sun Cellular and Digital Telecommunications Philippines Inc.
    According to a voice traffic monitoring report from the National Telecommunications Commission (NTC), congestion does exist between Smart's mobile phone network and those of Digitel and Sun Cellular.
    The voice traffic monitoring was conducted on the Gokongwei firms' end, with technical staff from the NTC's common carriers authorization department and Digitel doing the required tests.
    On the landline side, the test was done on March 31 from 10:30 p.m. to 12 a.m. the next day. For Sun Cellular, the monitoring activities were conducted on April 1 from 12 a.m. to 3 a.m.
    Results of the Digitel-to-Smart test indicated that out of 185 switches present, only 17 were occupied at around 11:30 p.m. This means that there were 168 idle switches.
    Despite this, only 13 calls out of a total 44 came through successfully, the report stated.
    "Based on the foregoing results, it appears that there is call congestion in the interconnection link between Digitel and Smart. Considering the average number of available devices out of the total of 185 available devices, call congestion should not have existed," it said.
    For Sun-to-Smart calls, the results were the same.
    At 1 a.m., out of 48 call attempts, only 10 calls were successfully connected.
    Despite proving that congestion did exist between Smart's network and those of Digitel and Sun Cellular, the NTC report said this did not prove that Smart was actually blocking calls coming from the Gokongwei firms' networks.
    "Congestion may either be due to several factors such as call blocking and restriction. However, it is not conclusive to state that the calls are actually being constricted.
    This requires that tests must also be conducted on the other end of the interconnection link," the NTC report said.
    Smart legal and carrier business group head Rogelio Quevedo said in an earlier statement that Sun Cellular was just using those allegations of call blocking as a "scapegoat,'' considering that Sun Cellular's call connection rate was way below the NTC-mandated 93 percent.
    Sep 2004
    hmmmm
    kaya laging maingay ang katabing kong dep't (carrier business)... nagaaway pa nga minsan... ;)
    Dec 2003
    hirap naman ata matrace kng talagang may deliberate blocking
    OT: for av8or5, silver_corolla and mazdamazda.
    recently kasi, nagkabit ng antenna ang isang telco sa isang building dito owned ng isang kakilala ko. nakausap nung kakilala ko yung technician/engineer na nagkakabit, sabi sa kanya, single bandwidth lang daw ang ginagamit nung telco dito sa area namin. kaya minsan meron congestion or mahirap tumawag. ang tanong ko sa inyo, ilan bandwidth ba dapat? ilan simultaneous calls ba ang kaya ng isang bandwidth?
    Signature
    Quote Originally Posted by BlueBimmer
    yan ang umuugong na rumor ngayon dito...
    Aug 2004
    Quote Originally Posted by boybi
    It is not the question of "ilan bandwidth ba dapat?" kasi isa lang naman talaga ang bandwith ng isang antenna (its either 1800MHz or 900MHz). So a single bandwidth has nothing to do with "congestion or mahirap tumawag". Congestion has something to do with the configuration of a cellsite (how many TRX per sector/site of the antenna). If it is not properly optimized, this will cause congestion, channel blocking, etc. For a fact, a sector of a site can handle simultaneous calls in a given time.
    nawala sa isip ko, yan nga pala yung single/dual band ng cellphones ! ang pumasok kasi sa isip ko nung una yan yung kung ilan ang kayang simultaneous calls na kayang i-handle. thanks for clarifying.
    yung isa ko pang kakilala, upon hearing it, gusto na agad mag text brigade para tumawag sa CS pa i-complain kung bakit single bandwidth lang ang ginamit dito sa amin
    Signature
    Mar 2005
    Dati nang style sa magkakaaway na carriers yan, i limit lang nila yung incoming capacity mula sa kabila sa existing trunk nila de mag que na ng mahaba pag simultaneous madaming incoming calls. Tapos gaganti naman yung isang carrier para masaya :lol: Pero on some equipments may record yan at puwedeng ma trace kung gusto ng engineer involved.
    yup. smart and globe runs on 900/1800 bandwidth, while sun is on 900/1900. so technically, yung mga triband phones lang ang uubra sa Sun ng maayos,although, tatakbo pa naman sya sa 900 mhz lang. yun nga lang, at certain places, talagang mahina signal.
    pero i really doubt if there are deliberate blocking involved. in the first place, why will Smart do that? tsaka ang hirap i-prove nun, unless yung magiinspect eh knowledgable dun sa mismong equipment and software na ginagamit ng smart.
    Dec 2003
    is there some kind of log to check for deliberate blocking? un lng maisip ko to trace up those blocked calls
    Mar 2005
    There is kaso mo di naman nila ipagkanulo sarili nila he he he... Saka sa equipment lang nila ang history noon sa kabilang side ang alam mo lang madami nang que outgoing mo papunta sa kanila yun lang. Yung ibang equipment nga puwede pang burahin history or alarm events. (Di ako taga Smart or Globe ha )
    Sep 2004
    Quote Originally Posted by silver_corolla
    silver corolla hit the mark. hands down ako...he sure knows his stuff
    Sep 2004
    Quote Originally Posted by happy_gilmore
    is 1900 bandwidth available in the Phils? As far as i know, only 1800/900 are available here.
    Mazda2: ano ba bandwidth ninyo?
    Aug 2004
    Quote Originally Posted by av8or5
    Hi av8or5,
    FYI.... http://www.gsmworld.com/roaming/gsminfo/net_phdt.shtml
    Br,
    Pete
    for those who believe that smart is not doing the blocking...read again the news, particularly the time of the test and how they did it. playing safe lang magsalita ang mga taga NTC which i don't know why. it's really a bullsh!t the agency that was tasked to control the national telecommuincation has nothing to do with what smart has been doing.
    there was actually a test also done by the same group (sun to globe) and it showed that the success of call is more than 90% (i also read this from the inquirer news)
    you don't have actually to read NTC's tests just to believe what sun has been complaining. i did so many tests myself by making a number of miss calls to smart numbers versus calling to globe and it prove not only once, not only twice...not only 10x that smart is really blocking the calls from sun to the smart subscribers.
    ako nga hirap tumawag sa mga smart subscribers. minsan talaga give up ako. pero sa mga globe subscribers wala akong problema.
    Strategy yan ng pldt...remember ginamit nila yan against Bayantel...ngayon using the same strategy in smart against Sun.
    Dec 2003
    unfair masyado smart, cla na nga leading telecom dto swapang pa tsktsk
    yup. 900/1800 ang Globe and Smart. Sun is on 900/1900. so if your phone is dual band (900/1800), pag naka sun ka, ang gagamitin lang nya is yung 900. that explains for example why in malls, mahina signal mo. but if your phone is a triband unit, ubra lahat. (900/1800/1900).
NTC test shows congestion between Smart, Digitel
