Anong ok na laptop in the 50 to 60k price?
Ok ba yung mga ECS, NEO, Prestigio brand? Yung mga Celeron di ba mabagal yon? P4 better?
hmmm..are they extending the promo here in the PH? i need the warranty eh...baka pag sa US binili hindi pansinin dito sa PH warranty
mag-ingat sa laptops -- baka ang makuha (lalo pag ECS) ay "portable desktops"
mabibigat ito.
tips:
1. with 10/100 lan (meorn na rin gigabit ethernet)
2. with wi-fi (wireless lan)
3. widescreen kung ok sayo / 15" lcd kung hindi
4. combo drive (dvd-read + cdrom [re]write, pwede rin dvd-rw)
5. ibm/toshiba/dell/compaq
6. wag celeron, at least 512mb of ram na kunin mo. doesnt matter kung ddr or sdr.
kung tight ang budget, better to get those used Pentium3 laptops (800MHz or higher)
upgrade mo na lang ang ram to say 256 or 512mb (3k to 5k).
50 thou to 60 thou, medyo mababa ata budget ah. i think it can only get an Athlon or a Celeron. Make sure the clock speed is a little bit high (e.g. Athlon 2.0 Ghz, Celeron 2.0 Ghz) tapos RAM should be at least 512 MB for Windows XP, kundi gagapang yan. Try Acer.
http://www.villman.com/products/pc_s...ks&nbbrand=all
meron dyan ibm p4-2.2ghz -- P68k
kung pwede try to get it without the bundled software - baka mas mura. buy ka ng winxp pro (kung ako edi WinXP Pro SP1 GH Version or better yet install RedHat 9 / Fedora Core2 Linux)
internet, cd writing, dvd movies and docs lang naman diba?
ok cattleya or corona notebooks...or kung tight ang budget mo...yung artista na lang ang cover. :bwahaha:
hehe..nanggugulo lang..:lol:
soree..peace!
bob, bili ka ng PC buyer's guide. P100 lang full color glossy magazine.
Ang dami doon mga laptops in that price range. Get something with a centrino in it.
post ko lang uli: lahat yan available locally (kuno)
get a dell.
US warranty ng lang yun.
depende kasi sa gamit.
pero mas ok yung mga lightweight lang.
mas practical dalhin.
make sure nga lang na
wi-fi ready
512mb RAM
30Gig-up HDD
centrino processor
CDR or DVDR
yun lang po.
PM or sms me if you are still looking.
will hook you up with the person i got my unit from.
although he only carries, dell or sony.
FRT;
I can help you with this.
Im working in a distribution firm of head end computers.
IBM, HP/Compaq, NEC, Apple to name a few.
If u want just text me 0917-8362878. pakilala ka lang.
Drop by at the ofc, here in libis para pakilala kita sa mga Product Manager namin din hingi tayo discount.
Just thought you'd want to know; my experience with service on laptops sa philippines, mahina ang dell, ok ang toshiba.
In my own humble opinion and if your wallet can afford it, there are only 2 names to remember when it comes to laptops.
1. DELL
2. TOSHIBA
The rest of the competition doesn't come close in terms of durability, features, and web technical support. Again, this is my own humble opinion.
I've owned 2 dell laptops since 1999. First was an Inspiron 7000 366Mhz. My second and my current laptop is an Inspiron 8100 1.0Ghz. My first one survived 2 falls from a height of one meter after having tripped on the AC adaptor which was attached to it. No problems. Sold it to my cousin to get my 2nd one.
Based on my experience and on the experience of my friends who have Dells also, technical support was never a problem here in the Philippines because they never had to have their laptops serviced in the first place. Maganda ang build quality ng Dell. Hope it stays what way.
Go for a Dell if you can.
im a toshiba user, n i dont recommend it, it's been with me for 2.5 years n it was reformatted 2x already, the hard disk collpased. n after the first year, the adaptor needs to be changed.
gastos sobra!
i dont recommend IBM, pangit yung external materials, too brittle
i'd go for compaq/HP
pansin ko lang yung mga latest models ng laptops, centrino na yung processor, what is its difference from P4?
got this from another forum...
Centrino is not a processor and not comparable with the others. Centrino is a marketing program based on adding an interface chip set and wireless chips to a Pentium M to create what Intel's ad agency calls a "mobile solution." It's not much better or worse than anyone else's mobile solution, but benefits from a far higher promotion budget than any of the others.
That said, my understanding (subject to correction by others more knowledgeable) is:
Pentium Ms have lower clock speeds than the others because it takes a lot of power and generates a lot of heat to push electrons through thin pipes quickly. Power and heat are both Bad Things in laptops. Pentium Ms make up for this to a degree by using circuits that get more work done per clock tick than a Pentium 4 does. You can therefore use a lower clock speed with a Pentium M than you'd need to get the same performance with a Pentium 4.
With Celeron, the reverse is true. It's a low-cost processor that omits certain performance-enhancing features that the more expensive Pentium 4s have. To get the same performance as a Pentium 4 with a given clock rate, a Celeron will need a higher clock rate.
To make things more complicated, AMD processors (fully compatible with Intel's, lacking only the "Intel Inside" slogan) are designed to run at a lower clock rate than Intel's but to do more work per clock tick. The net effect is much the same. Intel's higher clock speed does not translate into a comparable superiority in real performance.
And, should you also be considering Apple, the same applies even more strongly to its PowerPC processor. Its clock rates are not in the same league as Intel's, a perennial source of frustration to its marketing people who have to keep explaining that clock rates are not comparable across architectures, but its bottom-line performance is good enough for Virginia Tech to have built the world's third-fastest supercomputer from off-the-shelf Macintoshes - and for IBM to use the same chip in its top-of-the-line (i.e., above its Intel servers) server family.
