Results 1 to 10 of 10
Threaded View
    Your MMC is called just that - an MMC. Yun na mismo yung type niya. The 6600 was released way before the advent of SDs, microSDs, and miniSDs.
    For your battery, MSM-HK replacement batteries are good replacements. About 150-200 per piece in your nearest tiangge.
    Also, if I remember correctly, you bought a new laptop recently. That most probably has a built-in card reader. If it doesn't, CD-R King sells it for as low as 30 pesos each.
    Sent from my iPad using Tsikot Car Forums
    It worked! I found the slot in my laptop and it was able to read the MMC of my 6600! It only has pictures, videos and sounds saved.
    My problem now is I want to retrieve my contacts, messages and notes but it's not saved in the MMC. When I brought the phone to tiangges but they would say reformat to fix my Nokia's hanging problem. It does not even turn on now
    I got an MSM replacement battery but it's not charging. I think it's my charger that's the problem naman.
Nokia 6600: How To Revive
