Results 1 to 8 of 8
December 29th, 2003 03:27 PM #1
i just bought a NextBase 785 DVD --- the more popular among generic brand of DVDs. Gusto ko sana magset-up ng decent home theater on a low budget.
Question:
what generic brand would you suggest to buy for an amplifier, speakers, subwoofer?
how much do they cost?
where to buy these stuffs?
i just saw a NextBase HTIB complete set composed of NB DVD (dont know the model), 2 front speakers, 2 rear speakers, center speaker, and subwoofer amounting to P12K...kaso may DVD na ko. May nabibili ba separate NB speakers? Ayaw kasi ibenta ng di kasama yung DVD.
I tried to check with pinoydvd.com kaso dami na thread and a lot of catching to do. Tsikoteers who shared with the same interest...help!!
December 29th, 2003 03:59 PM #3
thanks ssaloon
medyo malakasan ang discussion sa binigay mong thread, i am into a low budget lang kaya generic brands lang ang ask ko. but thanks anyway sa reply.
- Nov 2002
- 87
December 29th, 2003 04:37 PM #4Maikikisali na ako dito...
I just bought an LG HDTV 44" Projection TV na may libreng DVD Player. Plano ko rin mag set-up ng HT kaso hindi ko alam kung anu-ano ang kailangan ko at paano ko pagko-konektahin lahat ng speakers para mabuo yung HT. Meron bang pwede magturo sa akin dito?
Also, may nakita ako na surplus na HT speakers daw. May sub sya na parang CPU ng PC plus around 5 small speakers. The package is worth 4K lang, Hitachi yata tatak. Okay na ba yun?
Sensya na kayo, medyo bago ako sa ganito eh. Dati kasi kinu-connect ko lang yung DVD Player ko sa component ko eh.
Thanks in advance!
God bless!!!
BANNED BANNED BANNED
- 3,790
December 29th, 2003 07:14 PM #5Budget HT ba ang gusto ninyo....base on my limited knowledge this is what I would do.
1) Check if 5.1 nga ang model ninyo...meaning, does it have an RCA jack for 6 speakers (Left front, Right front, left rear, right rear, center and subwoofer)?
2) If yes, then you can try testing them out muna. If not then, you'll have to buy an amplifier system na 5.1 ready.
3) To test, I suggest getting these test vcd/dvd/cd's for 5.1 systems....it plays audio to all the speakers so machecheck mo if it works.
I PLAN to use an amplified speaker set from my computer. To match the stereo plug...I made an stereo jack na RCA ang kabilang plug so it would fit the RCA jack ng nextbase dvd ko. Since, iisang pair lang ang amplified speaker ko, i use it on a pair of plug at a time. front muna, then rear, the center and sub combination.
I haven't done this step 3....kasi di ko pa napupuntahan yung friend ko na may test cd for 5.1 system.
Now, if this works,
4) I'd buy an affordable amplifier system. I have a pair of 50 Watts rating na 12 inch speakers (8 ohms) which I plan to match to a 75-100 watts stereo amplifier...I'll probably use this for the subwoofer. Then I'll get 6 cheap (Alexan) 25 watt stereo amplifiers (for 8 ohm speakers) and match it to small 6 or 8 inch speakers (if my calculations are right, I'll need 2 speakers for each amplifier so that would be 12 speakers)...each amplifier would be allocated to each of the channels...the wattage of the speaker would be around 15-20 watts (8 ohms din) lang (rule daw ay half of the amplifier power rating).
then I'll be making my speaker boxes din. estimated cost less than P5K except speaker box.
hth
Tsikot Member Rank 3
- 400
December 29th, 2003 11:44 PM #6Haay, hirap gumastos ngayon sa mga bagay na ganyan...
Anyway, punta ka pre sa Astrovision doon sa Podium.
Doon ko nabili yung 5 channel na speakers na Nextbase
ang tatak. P 2,500 lang. Of course, don't expect too much
from that dahil mura lang. Not as good as the pricey ones
but not bad either. Puede na for an entry level generic set-up.
Kinabit ko sa Xenon na DVD ko na may built in na DTS decoder...
- 10,620
December 30th, 2003 10:16 AM #7OIC,
as for the cost of our set ups, frankly i don't care whether you HTIBs or have home-made, locally-made HT systems , or maybe even obscenely priced set-ups. what is important is that you are satisfied with the sound, mas ok pa nga kung dirt cheap ang setup mo pero mag kasing tunog ng mga mamahalin eh,
there are so many ways to achieve entry level setup,
1.buy a DVD player with built in decoders, then buy a generic 5.1 amp (SAKURA, MEQUE, etc) ang dami nito sa RAON
then DTX floorstander speakers (3.8K) and 14 gauge audiopro
speaker wires, diyan palang
ma e-enjoy mo na lang, dagdag ka na lang ng speakers kapag may moolah ka na DTX center (1.7k), DTX rear (2.2K) DTX sub (6.5K)
or meron din speaker packages ang dai-ichi basta sa raon ang dami dun.
2. punta ka sa pier maraming nagbebenta ng surplus amp, speakers, widescreen tv, ingat lang surplus ang mga iyon, bring your trusty electrician.
mods paki merge itong thread sa home theater thread
, as i've said wala naman sa sing mahal ang setup eh, basta
we share the same appreciation for good audio and video
- 10,620
December 30th, 2003 10:26 AM #8depende rin pala sa budget, room size and preference
and may i add the daichi is an OEM manufacturer, sila din ang gumagawa ng DTX, US audio, Acoustic Research (mga export quality)and the sub contract on JBL, Cerwin Vega and many more baka magulat kayo mga high end sila rin ang may gawa.
best ofcourse gawang pinoy ang dai-ichi, tangkilikin ang sariling atin!!!
high idle RPM at engine start
