Results 1 to 9 of 9
    Sep 2006
    ano po kaya sira nito? nasa gitna lang sya, ayaw gumana ng adjust buttons ng monitor, na try ko na din na i-uninstall yung video card ayaw pa din, sira na kaya yung monitor nito?
    baka sira na ang monitor mo.. hindi ako masyado expert sa mga jan ha.. kung hindi na gumagana ang mga adjust buttons, then there's a possibility na sira na nga ang monitor mo. ako rin eh sira isang monitor ko. nakikita pa naman ang ginagalawan mo pero PULANG PULA ang kulay.. ewan di na siguro yun maaayos
    dalhin nyo na lang sa repair shop at ipa estimate. much better kung mag lcd na kayo
    Sep 2006
    thanks po, last time kase ayaw mag on ng monitor na yan, tinignan ko yung connection nya sa CPU, kulang ng isang pin, tapos akala ko sira na sya, pero nung pinatingin ko sa repair shop biglang umandar ulit sya, better patingin ko na nga lang muna
    Aug 2005
    Sa kin din, nagluko na. Pag on ko PC wala nang display, ung monitor indicator light naka green. Pag ni-reset ko monitor power button, meron abrupt display then turns black. Ano kaya defect nya? CRT po ung monitor ko.
    Quote Originally Posted by JJCarEnthusiast View Post
    that means, your green color is not working... Red, Green and Blue kasi ang colors ng crt monitor.
    could be a simple fault like plug or cable miscontact, to a bigger faults inside...
    May 2007
    Quote Originally Posted by bankai View Post
    You dont say which version of windows you are on? I will assume that your on windows xp if you are right click your desktop, select properties, then appearance settings and alter your screen resolution there. Or your video card is probably the culprit. Older video cards often don't support the 1.6:1 wide screen monitor format. Can you tell me what is your resolution setting format
    Jan 2003
    dun sa TS, im not sure kung capacitor yun or what. it just controls your vertical and horizontal adjustments ng monitor mo. replace lang nila yun.
    yun kay leinathan, bro malamang flyback yan. medyo mahal pagawa nyan, para ka na bumili ng bagong monitor.
    Aug 2005
    Quote Originally Posted by badsekktor View Post
    Thanks bro. Ok na yung monitor ko. Pinalitan ko lang ng power-on delay adaptor dun sa mains plug, reset CPU, oks na ulit. Was thinking of buying a new LCD monitor pero di na lang muna, he he he.
Need Help On Pc Monitor
