Results 1 to 9 of 9
April 29th, 2008 08:19 PM #1
ano po kaya sira nito? nasa gitna lang sya, ayaw gumana ng adjust buttons ng monitor, na try ko na din na i-uninstall yung video card ayaw pa din, sira na kaya yung monitor nito?
April 30th, 2008 07:23 AM #2
baka sira na ang monitor mo.. hindi ako masyado expert sa mga jan ha.. kung hindi na gumagana ang mga adjust buttons, then there's a possibility na sira na nga ang monitor mo. ako rin eh sira isang monitor ko. nakikita pa naman ang ginagalawan mo pero PULANG PULA ang kulay.. ewan di na siguro yun maaayos
April 30th, 2008 07:45 AM #3
dalhin nyo na lang sa repair shop at ipa estimate. much better kung mag lcd na kayo
April 30th, 2008 01:04 PM #4
thanks po, last time kase ayaw mag on ng monitor na yan, tinignan ko yung connection nya sa CPU, kulang ng isang pin, tapos akala ko sira na sya, pero nung pinatingin ko sa repair shop biglang umandar ulit sya, better patingin ko na nga lang muna
July 12th, 2008 06:33 AM #5
Sa kin din, nagluko na. Pag on ko PC wala nang display, ung monitor indicator light naka green. Pag ni-reset ko monitor power button, meron abrupt display then turns black. Ano kaya defect nya? CRT po ung monitor ko.
July 12th, 2008 09:06 AM #6
You dont say which version of windows you are on? I will assume that your on windows xp if you are right click your desktop, select properties, then appearance settings and alter your screen resolution there. Or your video card is probably the culprit. Older video cards often don't support the 1.6:1 wide screen monitor format. Can you tell me what is your resolution setting format
Tsikot Member Rank 4
- Jan 2003
- 2,979
July 12th, 2008 10:03 AM #7dun sa TS, im not sure kung capacitor yun or what. it just controls your vertical and horizontal adjustments ng monitor mo. replace lang nila yun.
yun kay leinathan, bro malamang flyback yan. medyo mahal pagawa nyan, para ka na bumili ng bagong monitor.
July 12th, 2008 11:13 AM #8
July 12th, 2008 12:24 PM #9
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
