Results 1 to 10 of 12
October 17th, 2007 05:39 PM #1
i got a problem with my cellphone, N70. when i press the button for "menu" the menu heading just pop out then comes back to stand by mode. what should i do? is there any other way i can access my menu? i think if only i can access my system explorer (this is an application) i can try to fix this one.
October 17th, 2007 06:51 PM #2
Try re-starting the phone. This happened to me last monday lang. After re-start, ok naman. Di naman naulit so far.
- Jan 2006
- 15
October 17th, 2007 06:56 PM #3you can hard reset yung phone, kaya lang lahat laman nito mawawala, ang matititra lang ay yung nasa memory card, all phones with symbian os pwede
October 18th, 2007 07:55 AM #4
October 18th, 2007 07:57 AM #5
October 18th, 2007 09:51 AM #6
October 18th, 2007 10:52 AM #7
heheh... i got a strong hunch kasi na i can fix this one. ang kailangan ko lang mai-hack ko na makarating ako sa system file other than normal way na thru the menu. sayang lang hindi ko naisama sa mga short cut keys yun system explorer. everything on my phone works right except of the said problem. i got a lot of applications na isa-sacrifice kung di ko na maibabalik yun dati ko settings at mag-stay na ko dito sa unit ko na reset. i even got there an application kung saan nakatago ang mga pins/password ko from banks and web security log-ons. wala pa man din ako ibang kopya.
ot: may battery is not included in the recall...
October 18th, 2007 01:04 PM #8
guys, is there any other way to reach a particular app other than passing thru menu???
October 18th, 2007 01:19 PM #9
have you tried to update your firmware? make sure to back-up first muna if you do.
used to have some problems with my N73 ME before. bumabagal, nag-hahang, no ringing tones because of the slowness of the unit. memory issues.. etc.
I then checked the firmware. turns out, they released a ver. 4 last july. so I updated. ayun so far, walang hangs and improved software.
October 19th, 2007 01:23 AM #10
turn off phone, remove memory card, turn on phone without the mmc...
if this works at naopen mo na yung menu, insert mmc then do what u must do..
pag insert mo naman ng mmc at nawala sa menu yung phone, then your mmc needs to be reformatted...
Monk-owned R53
