Results 1 to 10 of 31
- Nov 2010
- 57
June 10th, 2011 05:49 PM #1hi mga ka tsikooter.
need help, bibili po ako ng bagong pc sa sunday.
saan po ba makakabili ng mura na pc pero okay yung specs? 20k po budget ko.
yung pwede na rin po pang gaming. hehe
thanks!
June 10th, 2011 05:51 PM #2
Kung dito ka sa Manila, sa Gilmore madami. Makakapamili ka ng specs na pasok sa budget mo.
June 10th, 2011 07:03 PM #5
June 10th, 2011 07:20 PM #6
June 10th, 2011 07:30 PM #7
June 10th, 2011 07:42 PM #9
PC Hub, may braches sa Fairview at Gilmore..
http://www.tipidpc.com/useritems.php?username=PCHub
Tsikot Member Rank 3
- Mar 2004
- 2,053
June 10th, 2011 08:06 PM #10If you want to make the most out of your budget:
1) Find a techie friend and let him/her help you pick out the components from the item/price list of your selected store (e.g. PC Express, PC Hub, etc.)
2) Once you've picked out your components, call up the said store and make sure they've got the parts you want. If may kulang, choose alternative parts.
3) Once you've confirmed that all parts are available, that's when you go out to the store to make your purchase.
4) If your techie friend is capable of assembling the PC, then I highly recommend ask him/her to assemble it for you.
If you cannot find a friend to help you or you're in a hurry, then I strongly recommend you get one of the pre-packaged PC's like the one _Qwerty_ recommended -- Qube - Online. Bear in mind that you will still be able to get a more powerful machine for the same price. Pero less hassle.
EDIT: Pahabol
You mentioned that you also plan to do some gaming... what particular game did you have in mind?
The type of game will influence the type of video card you'll need which will in turn have a big influence on your budget.Last edited by ess; June 10th, 2011 at 08:34 PM. Reason: pahabol
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
