Results 1 to 10 of 34
December 3rd, 2004 10:12 AM #1
here's my setup:
PC1 (WinXP Pro), DSL modem connected to LAN card 1, LAN card 2 connected to HUB
PC2 (WinXP Pro), LAN card connected to HUB
i have run Network Setup Wizard on both PCs and i can share/transfer files already. but i cannot use/surf the internet using PC2. i have enabled ICS on PC1.
ano pa dapat kong gawin?
yung madali sanang initindihin ha, virgin pa ako sa networking e ;)Last edited by boybi; December 3rd, 2004 at 10:15 AM.
Signature
December 3rd, 2004 10:33 AM #3
konti lang alam ko sa networking pero ito dating set up ko...
dsl modem(naka router function) nakakabit sa hub...
mga lan ng pc's nakakabit sa hub via utp cable...isang lan lang per pc...
pagbukas mo ng internet browser ng pc nakaonline na agad...
let's wait sa reply ng iba pero kung pldt iyan dsl mo pwede mo ipa configure yung dsl modem sa technician ng pldt into router function para ikabit mo na diretso sa hub
December 3rd, 2004 10:38 AM #4
afaik u have to set the primary pc to the 1st ip address, then sa 2nd pc consecutive address. then enable internet connection sharing.
- Nov 2002
- 1,326
December 3rd, 2004 10:44 AM #5pinaka madali but may konti ka pang gastos..
buy a DSL router ... i think nasa mga 3k ata ang dlink.. mas cheaper pa ata ang linksys...
you connect a cable from your hub to the router... configure the router.. then viola!!! dsl connection for all!!!
December 3rd, 2004 10:51 AM #6
from my experience d mo na kailangan bumili pa ng ibang hardware..ok na yang set-up mo..its just a matter of configuring yng settings sa mga pc mo..yng skn dati pina-ayos ko lng sa friend ko so d ko rin alam yng details ng pag-setup..ang maipapayo ko lng is dont buy any hardware na..gastos ka pa!
..just my 2 cents!
- Nov 2002
- 1,326
December 3rd, 2004 10:58 AM #7Originally posted by mazdamazda
pwede bang wala nang hub? pc-to-pc na lan cable?
PC1 - LAN card 1 connected to the DSL modem
PC1 - LAN card 2 connected to PC2 (make sure na cross over yung cable)
PC2 - LAN card 1 connected to PC1
in this case.. PC1 is acting as a router....
para sa lan card connected to the dsl modem... basic lang ang config.. tcp/ip (auto ip address)...
dun sa 2nd lan card ng PC1, i'm not so sure how to configure na
yung PC1 to hub and PC2 to hub parang ganito din ata... dumaan lang ng hub yung connection ng 2 PCs... but di ko talaga sure pano config as a router yung isang PC..
December 3rd, 2004 10:59 AM #8
hindi pwede walang hub, 25 meters kasi ang haba ng UTP cable from PC1 to PC2. ang sabi sa akin kung PC to PC, dapat mga 3 meters lang daw.
yung DSL modem ko, walang router. pang single computer lang talaga. Nortel ang brand.Signature
December 3rd, 2004 11:08 AM #10
sa dami ng walls in between the 2 PCs, i will need at least 2 wireless access points. wala din ok na place para i-pwesto ang mga access points. pag ok naman yung place, wala naman outlet. at least itong wired network, naipadaan ko pa sa pvc conduit pipes within the walls.
Signature
Thread was made nung 2018 pa po sir.
