Results 21 to 30 of 34
December 3rd, 2004 01:46 PM #21
tama yung sinabi ni wowiesy na settings (at least ganyan pag dial-up connection yung shared, pero pareho lang ata pag broadband... hindi ko lang sure kung full functionality yung internet access sa both PC's with this kind of sharing)
TCP/IP settings for the LAN connection for the server should be: IP address: 192.168.0.1; subnet mask: 255.255.255.0; gateway should be left blank
TCP/IP settings for the LAN connection for the client should be: IP address: 192.168.0.2 (or 192.168.0.x); subnet mask: 255.255.255.0; gateway: 192.168.0.1; DNS server: 192.168.0.1
finally, enable internet connection sharing on the broadband connection on the server
check mo kung gumagana yung network connection by running (or sa command prompt) "ping 192.168.0.2" sa server; o kaya "ping 192.168.0.1" sa client. you should get responses
December 3rd, 2004 02:21 PM #22
Yup, that's true, a router will do the job. In our office, I configured a four port router to 4 PC's, and yes they all access the internet. The procedure to configure the router is already bundled in the installation disk of the router. Easy steps.
- Oct 2004
- 32
December 3rd, 2004 02:25 PM #23I agree with wowiesy.
DSL router is easier altough not cheaper,
pero you wont put pressure in your PC1 dahil they function individually.
meron kaming wireless lan/router before and 5 kaming gumagamit even inside the room, kitchen or out in the garden.
December 3rd, 2004 03:51 PM #25
kumuha na nga ako ng D-Link 4-port router. P2,500 ko nabili. pero bigla naman nasira yung motherboard nung isang PC ayun, napabili tuloy ng new motherboard and CPU.
Signature
December 3rd, 2004 04:19 PM #26
agree din ako na bumili ka na lang boybi ng isang DSL router para mas madaling i-setup and hindi kelagan naka switched on ang PC#1 para lang maka internet ang PC#2 ..
if you are planning to buy a laptop.. get a DSL wifi router na lang para mas okay..
FrankDrebin GuestDecember 3rd, 2004 04:36 PM #27Originally posted by boybi
Router is answer nga.
December 3rd, 2004 06:21 PM #28
in the absence of a router, download ka nalang ng internet sharing software (winroute, wingate, etc) - these softwares usually comes with their own firewall / antivirus and/or filtering functions - so para kang naka 2in or even 3in1 - mey router kana, mey antivirus kapa, meron ka pa ring filtering/firewall.... (sa greenhills meron atang cracked version)
most of these softwares are easy to install tapos auto detect narin lahat ng kakabit sa PC1/internet server.
hth
December 3rd, 2004 08:27 PM #29
Using one of your PCs as the router using software is the least expensive method. It does have disadvantages though, mainly less reliable because:
1. The router PC always has to be on. If this PC is often on most of the time it isn't a big deal, but when you don't use it a lot it just consumes more electricity.
2. PC 1 crashes, the entire network's Internet connection goes down.
3. Network performance might be bottlenecked by the router PC if it's under heavy load, but most of the time this isn't the case.
December 3rd, 2004 08:48 PM #30
paano kung 4 pcs? yun dalawa magkatabi... tapos yun dalawa sa taas ng bahay, tapos magkahiwalay sa ibang kwarto...
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
