Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 71 to 80 of 113
    #71
    Na for compatibility sake I got an ATI.
    #72
    Make sure to check your installed programs for nVidia's PhysX. ATI cards current doesn't support it which means your cpu will take a very steep hit if you use it.
    Me. I'm not sure how PhysX got into my pc. But, it was slowing down some games. So, I uninstalled it.
    #73
    Got my PC today, here are the specs...
    CPU: AMD Phenom II X4 945 (3.0Ghz)
    Mobo: MSI 790-GX-G65 (AM3 and DDR3 compatible)
    RAM: 2X 2GB DDR3 1333 Kingston (I figured at this stage 4GB is sufficient I have 2 slots left anyway, will buy as required)
    HDD: 1TB Samsung 7200RPM SATA 32MB cache
    GPU: ATI Radeon HD 4670 1GB (I know kinda low spec but its so hard to find HD 5000 series here)
    Sir
    how much damage ng rig nyo na to?
    #74
    Around P33K++ Mahal yung MOBO nasa P7000 na, yung Phenom II X4 945 nasa P9000. The memory is P5000 for both yung video card mas mura P3700 and the 1TB HDD is P4000... Binili ko sa PC Gilmore sa V-mall...
    #75
    Thanks sa info sir. hmmm. sakto, nasira yung athlon 64 ko. ) hehhee. mukang pasok sa budget to.. ^^,m
    Jun 2006
    #76
    I'd suggest that you go with a Gigabyte instead of an MSI. Make sure all capacitors are solid type. Also, Western Digital instead of a Samsung.
    #77
    Ang problem lang dito sa Gigabyte is ang hirap maghanap ng specs na gusto ko. Meron sa mga price list nila pero laging wala silang hawak special order pa... Yung hinahanap ko kasi AM3 socket na and DDR3 compatible na...
    #78
    Quote Originally Posted by Horsepower View Post
    oks. pero sir, question... Pano malalaman kung solid type yung capacitors ng Gigabyte na mobo?
    #79
    I think all motherboards switched to Japanese solid-state capacitors after 2006.
    #80
    ngayon ko lang napansin, i5 boards are capable of handling DDR3-2400?
    daig pa niya current i7 boards * 1600 lang...
    there are also i5 boards that go as cheap as 5.3k the Asrock P55M Pro, CrossFireX ready pa
Mid level gaming pc
