Results 31 to 40 of 48
March 31st, 2006 09:20 AM #31
bro, kahit sino man eh maiinis sa ginawa ng Meralco na 'yan.
pero marami na yatang case na ganyan na na-settle naman ng maayos. if I were you, I would take vicoyski's advice and talk with the branch manager, mr vargas AND name-drop the person who refer you... vicoy. Kilala 'yan sa Meralco, 'di ba boss vicoy? heheh.
as regards ERC's action, you can also consult them. just bear in mind that electric meters have two seals: one Meralco seal and one ERC seal. As far as I know, both entities test, calibrate, and seal them before use. What I'm saying is that the mistake was likely unintentional. you can also take matters to court.
whatever course of action you take, Meralco should explain to you in detail how the mistake and how the computed corrected billing came to be. They should accept installment payments. That's the least they could do after such a big inconvenience to you.
good luck!
March 31st, 2006 11:57 AM #32
Originally Posted by wowiesy
It's a matter of proving that you really used that amount of electricity. As a consumer, you can only rely on the correctness and accuracy of the electric meter installed in your premises. If the electric meter suffers a defect and that defect was not corrected in due time by MERALCO, it should not prejudice the consumer. Furthermore, assuming that there was a portion of electricity consumed but not paid by the consumer, I think MERALCO already recovered their costs because they charge consumers system loss charge. It may lead to a case of double compensation on their part.
- Sep 2004
- 59
March 31st, 2006 12:19 PM #33was just thinkin'
Just another example:
You received a hundred thousand dollars sent by one of your relatives abroad. Ecstatic about the fortune, you right away spent most of it buying cars, properties and other things you craved for. One day, the bank tells you that they had made a mistake. Your relative had sent you only a hundred dollars and a glitch in the computer had turned it to the above amount. You finally called your relative and you found out that indeed, he sent you just a hundred bucks.
Question:
Is it right to return the money to the bank?
Remember, what is legal is not always right. We tend to do something and want to make everything turn on our side and we take advantage on some refuge which will benefit our selfish interest. That's what the leaders of this country and many people do. If someone is not proven having done a crime, then he is innocent.
I am not on meralco's side. I'm just advocating for a good change in our society, and that should come from within ourselves.
If we can do the right thing though it hurts in some other way, then do it. If everyone else do the same, what do you think will happen to our world.
GoodLuck to everyone.
March 31st, 2006 02:17 PM #34
Originally Posted by Josh0027
April 2nd, 2006 08:32 PM #35
ang mahirap kasi sa case na yan, kung ilalaban mo sa Meralco baka magkatampuhan pa kayo at lalo pa kayo magkaproblema like occassional brownouts sa bahay ninyo. yes, tama yun sinabi dito na kung PLDT ka, it's so easy to switch to Bayantel or Digitel. but with Meralco, san ka pa? kung pangangatawanan mo prinsipyo mo, be ready to go back to the stone age ika nga ...
my question is hindi ba man lang kayo nagtaka kumbakit ang baba ng singil ng kuryente nyo?
April 2nd, 2006 09:16 PM #36
Originally Posted by CtrlAltDel
April 2nd, 2006 10:09 PM #37
Ang di ko lang po alam ay pag ganito na fault ng Meralco ay kailangan ba talaga sila ang masunod sa terms of payment? kasi nga kung nag overcharge sila dati ay may ruling ang SC na kailangan nila mag re-fund sa consumers.
April 2nd, 2006 10:25 PM #38
Originally Posted by ss3wiper
April 2nd, 2006 11:03 PM #39
at the end of the day, whether its the bank overpaying you or you are being billed for electricity actually used but not paid, the civil law principle of unjust enrichment will apply
art 2142 of the civil code states:
"Certain lawful, voluntary and unilateral acts give rise to the juridical relation of quasi-contract to the end that no one shall be unjustly enriched or benefited at the expense of another. (n)"
this principle was used by the courts in the vibram case decided by the supreme court
of course, there are certain exceptions to the above rule and that is where legal training comes in and the worth of your legal counsel will be determined
April 2nd, 2006 11:44 PM #40
for 170k you can buy a generator and tons and tons of gasoline for it :P
but it would be better to cite vibram and say 3 months lang bayad mo. after all sila nagkamali sa paglagay ng decimal point.
but toyota outfits their cars with locally manufactured yokohamas. i just follow suit. after many...
Finding the Best Tire for You
