Results 1 to 10 of 22
July 20th, 2007 06:51 PM #1
I have n73, equipped with 1gb mini sd. all of my images, videos and sounds are saved in mini sd. I have a free 864mb space on my mmc and on my phone memory i got a very low 173kb free memory. It is said there that 47mb are in use. where?! here's the breakdown, 10kb calendar, 78kb contacts, 25kb messages, 0b images, 0b sound files, 0b video clips, 180b documents and 0b applications.. i may not be good in math subject but there's no way these small amount of data's will reach the size of 47mb.
July 20th, 2007 07:07 PM #2
try deleting some messages, especially those that you received via bluetooth like mp3s if ever there are any in your inbox.
July 20th, 2007 07:08 PM #3
Bro, Click Messaging, the Options, scroll to Settings then Other. Scroll down to Memory in Use, and click Memory Card.
Ganyan din nangyari sa akin, naka-default kasi sa Phone Memory.
If it doesn't work, reboot or Revert to Original Settings.
Pag wala pa din, time to upgrade your firmware or you have a memory leak. Yung Symbian OS kasi occupies a lot of megabytes sa Phone Memory.
HTH
July 20th, 2007 10:52 PM #4
July 21st, 2007 08:29 AM #5
Some memory is taken by the OS. Others are taken by the INBOX, especially if you have received pictures or other attachments via MMS or bluetooth. It is also possible you have other co-current running applications. Make sure to exit the application (like internet browser, games, etc) once you are done with it.
July 22nd, 2007 04:35 AM #6
punta ka messaging, then yung "my folder". usually madami nakasave dyan na pics, music at videos passed thru bluetooth. check mo din files sa gallery, anything na walang drawing ng mmc sa tabi, it means sa phone memory nakasave yun.
also check the "manager" (not file manager) for installed apps in the phone memory. delete mo na lang yung di kailangan or you can reinstall it sa miniSD..
kung ayaw pa din, copy all your important data sa mmc..then do a master reset.
- Jan 2007
- 4,459
July 22nd, 2007 05:27 AM #7
July 22nd, 2007 10:46 AM #8
i think you can upgrade the firmware yourself for free from the nokia website.
July 22nd, 2007 11:13 AM #9
baka same scenario lang din ito sa n95? check out this link
http://www.gadgets.ph/tech/showthread.php?t=5042
""apparently, the n95 has 2 kinds of internal memory. First is the user memory, which can go up to 150MB, depending on the number of txt and apps you have on your phone. The second is the cache memory... which is only up to 25MB, this is the non-volatile memory that runs the apps and programs of the phone.
I think the reason why nokia separated this (from the usual internal user memory) is because they needed a buffer to "throw" the maps into before it displays into the screen. On some countries - like the US and UK, where the GPS maps can take up almost 8MB or more - it would bog down the phone if there's no buffer.
the other apps are handled by the usual internal user memory. (apps like texts, camera, gallery, and other usual stuff you can dump into the phone)
anyway.... one way to free up more of that cache mem is to delete unwanted apps that are runnin in the background. Like that welcome app... and that search app (which are barely used anyway). Once you've used it - you can also delete that setup wizard 2 app.
then install Handy Taskman or Best Taskman to tell how much your internal cache memory is. From the usual of 10 to 12MB, you now have around 18 to 19MB that's free. Which is now good enough for wifi, bluetooh, and gps all at the same time. :D
cheers!""
HTH..
July 22nd, 2007 05:26 PM #10
I already did, but unfortunately it wasn't successful. natuluyan na kung baga! cguro nasa last 2-3 steps na ako ng upgrade when the phone turned off then ayaw na mabuhay. i don't know what went wrong, i immediately send the phone to the company who gave it to me then told them.. "oh ayan, natuluyan na.. nasira na talaga. dati lagi na lang low memory tapos ngayon ayaw na mabuhay." meron pala master reset noh aside from restore factory settings. try this *#7370# then press call/send.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
