Results 11 to 20 of 26
January 9th, 2008 02:10 PM #11
January 10th, 2008 01:14 PM #12
i have an old modem US Robotics but no scanner. i need only the scanner coz meron mga clients na they need their quotation by email and they need my siganture.
n5110; its HP 4355 na.
and yes naisip ko na rin yung scanning capabilities. i am thinking of buying a separate scanner na lang. yung kaya ring scan ang makakapal na items.
thanks for the inputs guys
January 10th, 2008 02:22 PM #13
boss sa epson sulit kayo kahit libro ang iiscan at naka bukas yung takip aus lang maganda ang scan maraming settings pero madaling gamitin
August 12th, 2013 05:03 PM #14
UP
Pano gumana yung fax machine? ok lang ba sya na sa regular PLDT line tapos pag mag fax convert na lang sa fax line? may extrang bayad pa ba to?
TIA
August 12th, 2013 05:36 PM #15
fax machines will work on any phone lines. No need to pay extra nor any "conversion" needed.
Fax machines transmit a document by converting the document into tones as each line of the document is scanned by the machine. The receiving fax machine does the reverse, converting tones to black dots on the paper as each line is moved forward.
The technology is pretty much similar to how dial-up models work (if you experienced dial-up modems when trying to connect to the internet many years ago).
August 12th, 2013 05:48 PM #16
ano ba mas cheaper na all in one fax/scanner/photocopier epson or canon?
- Aug 2013
- 16
August 20th, 2013 06:47 AM #17Dont get the cheapest one brands as the ones you have mentioned. I will pick any good from Brother.
August 20th, 2013 12:11 PM #20
HP Officejet 4355 all-in-one gamit ko, 5 years na buhay na buhay pa.
Canon, Epson at HP for me are safe choices.
I think THAT may very well be one of the likely reasons. It's quite evident that the cooling...
