Results 1 to 10 of 10
Tsikot Member Rank 3
- Mar 2004
- 2,053
May 8th, 2014 10:01 AM #1I don't know if this belongs to the Detailing thread, but since the affected item is a PC Mouse, I opted to post this here.
I have two logitech mice. The sides of both mice are coated with this rubber like surface. After a couple of years of use, that surface has become sticky. On my other mouse, it has become so bad that I was able to scrape off the rubber like coating with a plastic knife. Very messy. It was like scraping off gummed up sticker adhesive.
The coating on the other mouse is still intact but already as sticky as a post-it note.
Is there some chemical I can use to restore this coating back to its original state?
If not fixable, is there any chemical I can use to quickly strip off this coating without damaging the surface underneath?
- Jul 2011
- 1,711
May 8th, 2014 11:05 AM #2
May 8th, 2014 11:38 AM #3
Kahit anong brand ng mouse sir basta may rubber coating na ganyan after a year or less ganyan talaga nangyayari
Pwede na dyan yung MC Multipurpose cleaner na cream para maalis yung tira. Just apply the cream then gamitan mo ng basahan to rub off the remaining rubber... repeat as necessary
May 8th, 2014 11:47 AM #4
How expensive is your mouse ba? Minsan mas ok bumili na lang ng bago kesa magrestore pa ng existing mouse mo.
Plastidip cost 600 per can kung iispreyan mo yung sides ng mouse mo.
May 8th, 2014 05:58 PM #5
May 9th, 2014 01:52 AM #6
Subukan mong gamitan ng isopropyl alcohol at baka matanggal yung rubber coating.
Posted via Tsikot Mobile App
- Aug 2011
- 564
- Jul 2011
- 584
May 9th, 2014 09:12 AM #8mas maganda sa detailinig forum section mo binato issue mo, mas madami may experience doon ng trim/rubber moisturizer or protection.
parang ang hirap yata i-salvage nyan base sa kwento mo.
- Mar 2004
- 2,053
May 9th, 2014 11:16 AM #9It's a logitech mx518. I already forgot how much it cost when I got it some years ago. And save for that annoying rubbery coating, it's very durable and reliable.
I'm not looking to restore the mouse. That would be very impractical.
I just want to get rid of the stickiness. If it means getting rid of the sticky surface then I'm all for it.
RE: MC Cleaner
Oo nga no! I remember that was potent enough to get rid of gummed up sticker adhesive. I think I still have a can. Try ko mamaya.
May 9th, 2014 11:26 AM #10
high idle RPM at engine start
