We will see what other TV technology our engineers has to offer in the future......
for the time being, ites either LEd-LCD LCD or Plasma, lets enjoy it...![]()
kung LED talaga gusto nila. ipasok nila dito ang OLED tv's. tanda ko pa nung unang nilabas ng sony and OLED tech sa japan. only 11inches for i think 1 or 2 million yen with 3mm thickness.
pero nung binili ko yung plasma tv ko. yung hard panel ang main factor sakin dahil may toddler ako sa bahay. second na lang yung PQ at minus yung kain ng kuryente.
Kung sa dalawa i'd choose the one with the higher khz factor. Sa store try nyo i compare ang clarity ng widely sold and cheaper 60khz lcd or Led TV. Then compare it witha 120khz or higher LCD or LED tv, its a world of diffrence especially if your playing Blue-ray or HD movies...
Check any store for sure mas mhal ang sa 60khz ang 120khz & up because it gives better picture quality...
Sa trinoma via Mindanao parking L3 or L4 meron dun store malapit sa entrance display ng 3 TV (1) 40"+ 120khz, (1) 40"+ 60khz & (1) 32" 60khz
Picked this up from yahoo...another thing to think about when buying a TV.
http://finance.yahoo.com/news/Seven-....html?x=0&.v=1
Seven Tech Trade-Offs Worth Making
PAY FOR TV SIZE, NOT REFRESH RATE As Matt Buchanan pointed out in a still-useful post on Gizmodo.com a year and a half ago, every television manufacturer has a sweet spot when it comes to price and size. Going to 50 inches from 42, Mr. Buchanan explains, may cost you $200, but going 54 inches from 50 could cost $400 more, so 50 inches is where you would get the most for your dollar. Every manufacturer has its own sweet spot, so it pays to look at the lineup and see where it is.
But one thing you do not have to spend much time looking up is a television’s refresh rate, measured in hertz. That tells you how many times per second the TV refreshes the image on its display. A 60 Hz television refreshes its image 60 times a second; a 120 Hz does it 120 times a second. Many — if not most — TVs now have a refresh rate of 120 Hz, and more expensive models are faster than that, refreshing the image 240 times per second. And while twice as fast is theoretically better, your eyes would be hard pressed to tell the difference. That is not a tradeoff, that is a ripoff.
So LCD na nga lang para hindi na-ripoff at 120 hx lang puwede na. hehe![]()
Fasten your seatbelt! Or else...Driven To Thrill!
just get the one that can play external hard disks.. para hindi na bibili nang media player.. sa Samsung.. Series 5 and above sa LCD.. sa LED nila.. yung series 4 nakaka play na din nang hard disk.
This misconception sometimes gets up my nose. Most especially when you try to explain to a person the actual definition of the tech to somebody and he stubbornly insists that LCD and LED are different.
Brainwashed by marketing people. Probably the type who thinks Bose is the end-all and be-all for the best sound equipment.
Note sa mga may balak bumili ng TV na kaya magplay ng media content from a hard disk....the only disadvantage I can see is that codecs are updated many times. Please make sure that support for the TV is consistent so that it can read updated codecs whenever available.
parang ps3 yata eto bro sinasabi mo na usually FAT format lang. hehehe. if the built-in media player can only accomodate SD videos, then no thanks. A high resolution TV is just inefficient if you cannot atleast match its native resolution. If it can play HD vidoes, then its definitely good. tama na bilin mo na yung biggest na ma-aafford mo.
