Results 1 to 10 of 12
May 10th, 2012 05:25 PM #1
Hi. Na experience ninyo na ba ito? The Home button is sometimes not responding. I have to press it 3 to 5 times just to respond. Any helpful solution on this para di ko na dalhin sa Mac Center? Mine is Ipad2 32G wifi+3g. 3 months pa lang from the date of purchase.
Thanks in advance.
May 10th, 2012 05:58 PM #2
Na reboot mo na ba? Warranty na yan, JB k n Lang para ma install ka activator para hinde malaspag home button
May 10th, 2012 06:21 PM #5
I'm with shadow. But don't ignore the problem using software workarounds just yet. Sayang warranty. Papalitan mo and THEN enable the software gestures to save the home button from future failures.
FWIW, iOS 5.x also gives you the option to enable multitasking gestures (four or five-finger pinch will take you to the home screen). I use this more than pressing the home button. May buhay kasi mga mechanical switches.Last edited by oj88; May 10th, 2012 at 06:24 PM.
May 10th, 2012 06:30 PM #8
Ang problem lang sa touch-sensitive na home button, kapag nag crash yung iDevice, pwedeng madamay yung touch circuitry at hindi kana makapag-recovery mode. Iba pa rin ang hardwired na switch.
Unless they add a reset hole sa likod.. but knowing Apple, parang malabo.
May 10th, 2012 09:48 PM #9
if it has the backlight bleeding issue bring it to apple and they'll replace it with a brand new one no questions asked.
- Oct 2009
- 2,271
May 11th, 2012 06:55 PM #10palitan ng home botton flex yan sa loob babaklasin yan
medyo may kahirapan ang proseso..
parang nag top overhaul ka ng engine..:D
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
