Results 1 to 12 of 12
    Aug 2010
    Hi. Na experience ninyo na ba ito? The Home button is sometimes not responding. I have to press it 3 to 5 times just to respond. Any helpful solution on this para di ko na dalhin sa Mac Center? Mine is Ipad2 32G wifi+3g. 3 months pa lang from the date of purchase.
    Thanks in advance.
    Na reboot mo na ba? Warranty na yan, JB k n Lang para ma install ka activator para hinde malaspag home button
    Aug 2010
    yes boss shadow.. tried reboot and hard reset but still no effect...
    warrant na yan or JB, activator lang katapat niyan
    Jan 2009
    I'm with shadow. But don't ignore the problem using software workarounds just yet. Sayang warranty. Papalitan mo and THEN enable the software gestures to save the home button from future failures.
    FWIW, iOS 5.x also gives you the option to enable multitasking gestures (four or five-finger pinch will take you to the home screen). I use this more than pressing the home button. May buhay kasi mga mechanical switches.
    Aug 2010
    thanks to your replies... i will be bringing this to Mac.
    Dapat Kasi yun home button virtual na rin eh.
    Jan 2009
    Ang problem lang sa touch-sensitive na home button, kapag nag crash yung iDevice, pwedeng madamay yung touch circuitry at hindi kana makapag-recovery mode. Iba pa rin ang hardwired na switch.
    Unless they add a reset hole sa likod.. but knowing Apple, parang malabo.
    if it has the backlight bleeding issue bring it to apple and they'll replace it with a brand new one no questions asked.
    Oct 2009
    palitan ng home botton flex yan sa loob babaklasin yan
    medyo may kahirapan ang proseso..
    parang nag top overhaul ka ng engine..:D
    Jul 2003
    I have this "problem" with my 1-month old iPad2.
    What I do now is have the on-screen home button.
    And if I need the actual home button, I use the thumb to press it instead of just the tip of the finger. I press is for a split second longer than usual and it works for me. It seems that there is some sluggish reaction from the software.
    Jul 2003
Ipad2 Home Button is unresponsive :help:
