Results 31 to 34 of 34
December 3rd, 2004 08:59 PM #31
tsip v-wilder
kung more than two pcs, get a hub, a 4-port hub...
UTP cables can usually handle a good distance of 100 meters max, beyond that mey possibility na ma lost signal na. kung ganon talaga kalayo yung i-kokonect mo, coax cable na sagot dun! (layo namang kuarto nun!)
December 4th, 2004 02:28 AM #32
na ayos ko na network connections dito. using a D-Link router. everything's ok, internet and file sharing.
nag transfer ako ng around 4GB of MP3s to the other PC, ang bilis! pero bakit dun sa counter ng network connection e ilan mb lang ang na transfer?Signature
- Nov 2002
- 1,326
December 4th, 2004 02:45 AM #33Originally posted by van_wilder
paano kung 4 pcs? yun dalawa magkatabi... tapos yun dalawa sa taas ng bahay, tapos magkahiwalay sa ibang kwarto...
dun sa 2 magkatabing room.. you can use wifi... or copper cable (cat5 utp).... but from this room (w/ 2 PCs) up to the other 2 PCs sa upper floor.. kailangan talaga mag latag ng cable.. 1 each to the room with 2 PCs.. dun mo na i setup yung hub, pati na yung DSL modem (if you're using one)...
- Nov 2002
- 1,326
December 4th, 2004 02:50 AM #34Originally posted by boybi
dito sa amin kasi.. ang setup namin... 5 online users... dito sa room ko.. sa room ng sis ko... sa room ng parents ko (who's in a different unit sa bldg).. and sa room ng other sis ko (who's in the same unit as that of my parent's).. and then isa pa sa store namin sa baba (ground floor commercial space ng bldg).. pinalatag ko ng cable lahat.. and then ako na ang nag terminate... powered on a 24 port switch na hindi ginagamit sa planta.. then kabit ng dsl router...
sa ganitong setup.. so far nagiging problems ko pa lang ay:
1. some ports of the switch gets busted.. still couldn't trace why this is so..
2. sobrang bagal ng bandwitdth... sometimes i trace this to a heavy user in our network.. but minsan i find out na nagloloko ang router.. i just switch it off (24 port switch, dsl modem and dsl router) and after about 2 mins eh on uli.. okay na...
3. particular clients complain of not having internet access from time to time... minsan ginagalaw ko lang yung cable ... although not sure talaga bakit ganito minsan...
i had mine replaced, but at the manila end. the las pinas end was closed at that time, kasi....
costal expressway
