Results 1 to 12 of 12
    paano po ba alisin kasi everytime buksan ko ko computer labasan agad tong mga programs na in-istall ng mga bata. (i.e.) AOL Instant Messenger, Window live messenger, at kung anu ano pa.
    TIA
    Aug 2005
    Quote Originally Posted by OiC65 View Post
    TIA
    To Uninstall - go to start>control panel> add/remove programs. then uninstall the programs u dont want.
    To disable startup items. go to start> run> type MSCONFIG> press enter. go to STARTUP Tab. disable the items u dont want. u will need a restart. a message will pop up. just click "OK"
    HTH
    In addition to what NazQ already said.......
    If you want to keep the programs but not have them start up, go to each program's Preferences and unselect, "Start program when Windows start" or something similar.
    This is best if you're sharing the pc with someone else and they have a need for those particular apps.
    Jun 2007
    msconfig will do the job if its not present in msconfig search in your startup folder or in your regedit (search in google for more info)
    +1 sa lahat ng nagreply....
    Jun 2006
    Agree with the above.
    Incase you dont know which startup item you can safely remove, use google. Just google the name. Ex. in my startup items I have "avgcc" with google, I know its my antivirus program so I will leave it alone.
    Another way is if you have CCleaner. Click Tools > Startup, click the offending item then delete.
    Dec 2003
    the best thing you can do is to go to systems configuration utility.
    start>run>msconfig
    go to STARTUP tab at the far right.
    click on DISABLE ALL on the lower right.
    put a check mark on your antivirus programs and then APPLY.
    Reboot is needed to complete this resolution.
    HTH
    i tried the msconfig way, ok nga kaso yung wifi ko nawawala...(I unchecked all kasi)... alin kaya dun yun sa wifi para hindi ito madisable.
    Feb 2005
    i think it would be better if you uncheck the items one at a time to figure out which are the ones you need to keep and the ones you can remove. As what the others said, it's better to google the listed item to figureout what it does before you decide to disable it from startup.
    Aug 2005
    ^^yep.. better check it one by one, especially if you dont know what your doing.
    just use the following site if you want some info regarding a certain item in the startup tab:
    http://www.sysinfo.org/startuplist.php
    Check the "Command or Data" column (in the sysinfo.org website) also when verifying a startup item because a lot of trojans have names similiar to legitimate programs.
    HTH
    Dec 2003
    Quote Originally Posted by wildthing View Post
    you just have to put a check mark back on the programs that you dont want to be disabled upon startup..
    another suggestion is create a new profile on your machine and from there you can edit the start-up programs...
how to remove annoying startup programs
