Is it possible for Windows to go straight to Desktop screen whenever I boot up my PC without having to click on a user account?
what OS are you using?
if youre using XP here's how
1. To change your login settings, click Start > Run (Windows Key+R) and type control userpasswords2. Uncheck the box next to Users must enter a user name and password to use this computer.
2. When you click the Apply button, the Automatically Log On window will pop up. Enter your username and password in the appropriate boxes. The next time you reboot your system, it should log you in automatically.
or maybe:
this will happen if you install dotnetfx, it will create a new user...
just go to your control panel > user accounts > delete the new user or guest user
-Go to control panel
-Select “User Accounts and Family Safety”
-Select “User Accounts” option
-You will see at the top portion “Make changes to your user account”, select “Remove your Password”
-Now you will need to put a current password. Then select remove password to confirm. The close the user account window...
Or use the Advanced User Accounts Control Panel.
- Click the start button then type “Control Userpasswords2″ in the Start Search box.
- To configure the automatic log on, select your user name in the Users For This Computer list, if it isn’t already selected. Then clear the Users Must Enter A User Name And Password To Use This Computer check box.
- you’ll see the Automatically Log On dialog box,then you will need to type your password in both the Password and Confirm Password text boxes. To complete the operation, click OK.
hope this helps.![]()
