Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    #21
    Quote Originally Posted by swordsman View Post
    I'm planning to have Data Cabling in our house. I don't know how this is implemented, but i guess each room should have an outlet/provision for data cable connection, so i can just plug in my data cable and surf the internet(thru my DSL connection) anywhere in the house. The data cabling will run thru the house along with the telephone and cable tv, in a common piping, i suppose.
    So how is this implemented? Is there a switch somewhere that that will receive the single signal from the telephone, cable, and data(dsl signal) and distribute it thoughout the house? Is the switch just a splitter of signal or something more sophisticated?
    Any tips or best practice for making this work with minimal problems? What type of cable/jack to use, to make it future proof a bit.
    I will try to help
    materials for voice, IP camera and data cabling: patch cord user side, Information outlet, faceplate, cat 5e cables, Patch panel , patch cord for cross connection, cable mangement,close cabinet, switch 10/100 (with POE for IP cam) for data and router ( if carrier provide modem/router good for you no need for router) and for voice if you need intercom ,door opener and you want to transfer your call you need PABX.
    you can use cat 5e solution or cat 6 solution for gigabit connection.
    How many outlet you going to install in your house?
    in every phone, IPcam and data connection you have to layout individual wire using cat5e. If you going to install PABX dont use jacketed wire after short period of time you can hear noise in your line.EX. FM station
    for CATV connection
    staright connector, faceplate, RG6 connector, RG6 Cable,( ask your contractor for RG6 not RG58), Spliter, indoor amplifier, then Catv provider or satellite attena.
    all outlet will be installed with individual wire going to termination box were catv will placed.
    sana nakatulong or naka gulo lang lalo
    #22
    actually, since may renovation sa house, i'll have the contractor implement this. i just don't know how good he is at implementing something like this, or if he knows how at all.
    wi-fi is also nice, and most likely will use it soon, in conjunction with the wired connection. i just want to have the data cabling implemented properly, since mag-re-renovate naman.
    are there individual contractors specializing in implementing structured wiring? kung hindi man kayanin ng contractor ko?
    Meron naman trained for that field. some electrical contractors they dont have xperience for this field also some arhitec di rin nila include voice and data sa design. Check the design ng electrical contractor mo sometimes all voice port in parallel connection .:peace:
    Jul 2006
    #23
    gumamit na po kayo ng Cat6 cable tutal lahat naman tayo papunta ng Gigabit LAN... A combination of Wireless N + Gigabit LAN ang magandang infrastructure mapabahay man o business
    Nov 2006
    #24
    i was trying hard not to make a comment here but it seems like your still having plenty of questions about what you want to do.
    im a low voltage technician and tht is part of my job.we do wirings for CATV,CCTV,networking,home theater,phone,burglar and fire alarms.
    everything that X-wind mentioned pretty much covers everything.
    where do you live?if its anywhere near chicago...ill give you a hand on how to run things and parts you need.
    sorry if i dint chimed in alot earlier.its just that ive been doing this job for 10 years and its the last thing i want to talk about when i get home from work.
    since your gonna wire th whole house..i suggest doing this
    1 room
    1 cat5e for internet
    1cat5e or phone
    2 or 3 RG6 for TV(depending on what cable company or satellite company youll use.cable/satellite company provider that also provides TIVO and HD signal will require atleast 2 RG6)
    run all phone,networking and cables to their respective boxes(onQ box).mostly go to the ponit of entry of the outside phone lines and cable lines from the outside pole(some are underground going to your house)
    #25
    eto po yung ginawa ko sa bahay....
    placed whole house surge protection by leviton..
    all wires from demarc go into one central location [home run or structured wiring], from there all rooms get their own 2 cat5 and 2 rg6 with the exception of our home office which has 2extra cat5 which I can use for phone or data.
    Jan 2009
    #26
    Reviving an old thread.
    This is how our home data network is setup. Big family kasi. Horizontal and vertical cabling are all Cat6 Belden cables.
    It's all-gigabit ports on all the switches as well. Absolutely NO WiFi repeaters or powerline adapters crap on my network. ;)
    The VPN router (Buffalo with DD-WRT + OpenVPN) allows us to access US-only sites like Netflix, Hulu Plus, Pandora, etc.
    The core...
    Sep 2012
    #27
    Good Job on that setup
    I'm just imagining gaano kadami kinain momg Cat 6 Belden? Yan ang favorite cables ko rin kaso minsan ang hirap i recommend sa ibang tao kasi tinitignan lang is price
    Jan 2009
    #28
    Quote Originally Posted by jodski View Post
    Used up around 200+ meters. All my runs are dual-homed kasi. Bought one roll (300M) and it came in a wooden spool.
    For data cables, you really get what you pay for. I've tried the China-made generic brands na "Cat-5E" kuno.. most of them aren't even stable at 100mbps, much less 1gbps.
    Sep 2012
    #29
    Yung mga China made na mura na Cat 5e hindi talaga nila inaabot yung 100 meter limit....
    Proven and tested talaga sa akin yang Belden... The last installation that I made lasted for 5 years and still stable... madalas na problem na sinasabi nila sa akin is napuputol lang yung lock ng RJ 45 kaya ayun tinuruan ko na lang mag crimp
    Jun 2006
    #30
    *oj88, that must cost a fortune to operate and maintain. hehe
    How many watts in all, for the whole network to run?
    Jan 2009
    #31
    Quote Originally Posted by Horsepower View Post
    Using a power meter, the total consumption of the core equipment (2nd pic), including the parasitic load from the UPS (~10W) is 140W on average. The server probably takes up close to 2/3's of that total. In fact, the 7 hard disks alone consumes anywhere between 36-40W combined.
    The 2nd and 3rd switches goes to the respective houses of my parents and siblings, so any power they consume are not included in my electricity bill.
    Aug 2003
    #32
    sir, anong power meter po gamit nyo? Kill-A-Watt?
    Jan 2009
    #33
    Nope. I have the one manufactured by Omni (Omni electrical - lighting Limited).
    It's available at Ace or Handyman for a little under P1k.
    Jul 2013
    #34
    If i was at the same stage, also would advise someone to explore wi-fi that's less expensive to help put into action and maintain.
    kasi pag cabled community ka, in the end, you can swap the actual UTP5 cables dahil minsan nadedegrade yan ng moisture. let alone, minsan, nginangatngat pennsylvania yan ng daga.
    _______________________
    Looking for more information on Voice And Data Cabling : Telesystemscorp
Home Data Cabling
