Results 1 to 10 of 33
January 13th, 2010 12:22 PM #1
ganito kasi yun:
- iniwan ko kahapon na naka suspend mode dahil I have to do something outside, hindi ako nagpapatay kasi ng computer, if i know na may kailangan pa akong gawin. saves on boot-up times, ika nga.
- when i went back, naka BSOD na sya... Memory dump.
Ngayon pag starting na sya, namamatay before I even reach booting of windows. I also noticed na pag nakakalusot, ang bagal ng POST nya, and minsan hang sya. Pero most of the time, siguro mga 80% nagshushutdown sya, even after the POST (kung nakakalusot). In fact, maski nasa loob ako ng CMOS configuration, namamatay sya.
I have already made some isolations, hindi RAM ang problem.
Possible kaya na sa PS ito? o sa board mismo?
TIA
Tsikot Member Rank 3
- Mar 2004
- 2,053
January 13th, 2010 12:38 PM #2Try to do a visual inspection of your motherboard's capacitors for possible leaks.
You can also check if your processor's HSF is working properly.
If the fan is dead, then your processor could be overheating and will either throttle down (hence the slowdown), and as an added safety feature, your motherboard might opt to power down as well. Pero I doubt ito yung cause ng problem mo....
January 13th, 2010 12:40 PM #3
- Mar 2004
- 2,053
January 13th, 2010 12:46 PM #4I guess the next best thing to do is to try to borrow a PSU from and test it on your system to find out if it's really the culprit.
I experienced something similar to your problem last december.
My 2 year old S939 motherboard died on me. At first intermittent bsod. Eventually, ayaw nang mag POST. I gave up and got a new system na lang .
January 13th, 2010 12:46 PM #5
Sounds like a motherboard problem to me.
But since PowerSupply are cheap, you can borrow a known good PS to check just in case.Last edited by ghosthunter; January 13th, 2010 at 12:52 PM.
January 13th, 2010 12:53 PM #6
January 13th, 2010 01:19 PM #7
FrankDrebin GuestJanuary 13th, 2010 01:20 PM #8
Chief HappyG,
I'm sure naman na there's no OS or malware issues, so crossout na natin yun.
Possible causes:
1. Defective MOBO
2. Defective PSU
When you say namamatay, did the LED or fan were still on? Or total shutdown talaga?
January 13th, 2010 01:32 PM #9
FrankDrebin Guest
Must have jinxed myself somehow. Was headed south around noon. A truck dropped its load of...
Traffic!
