Need help looking for a new battery for my epass. Its 3.6 volts and AA sized. Normal AA battery is 1.5 volts so cant use it.
I've also thought about replacing the batt on my epass pero from what I gathered before pareho lang halos magastos kung bumili ka ng bagong unit and palitan batt, so bumili na lang ako ng bago.
what I'm looking for now is if anyone can program the epass para maging unlimited ang credit.![]()
Use your cigarette lighter interface. Output is 12V,- then put a regulator and set it at 3.6V and solder its terminals to your epass.
After that,- no more changing of the battery....
13.9K:mop:
^ uy... pwede pero I still need unlimited load...
meron ako nabasa before nahulog niya epass niya then naging unlimited for a couple of months yata na stock sa P1000 yun load niya kahit hinde na siya nag load.
Went to the Greenhills battery store. They quoted 1500 for the battery. Did not buy. I did open the epass and put it back together. For some reason it now works better than before opening.
^told you...almost the same lang magagastos mo kung palitan batt and bumili ng bagong unit
there is still a battery shop in V-mall on 4th floor. pero kung 1500 yung battery bili na laang ako bago.
just a thought... what if you solder those solar cells from china calculators... para laging charged.... hmmmmm pwede kaya?
Each solar cell is 1.5V,- so not sure how many cells you have to solder to get 3.6V.....
14.0K:bike3:
Meron kau makukuha na EPASS BATTERY dyan sa Paranaque sila. They are supplying Original EPASS BATTERY. i got their number 02-9190817 or txt nyo 09199916188
