Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Jun 2006
    Need help looking for a new battery for my epass. Its 3.6 volts and AA sized. Normal AA battery is 1.5 volts so cant use it.
    Here is a DIY solution: Diy Epass Repair
    Jun 2006
    Thanks GH. Aside from Raon, where can I find the battery?
    I've also thought about replacing the batt on my epass pero from what I gathered before pareho lang halos magastos kung bumili ka ng bagong unit and palitan batt, so bumili na lang ako ng bago.
    what I'm looking for now is if anyone can program the epass para maging unlimited ang credit.
    Quote Originally Posted by userfriendly View Post
    There was a store in the old Virra Mall called Battery King who sold all kinds of battery including rare types. Unfortunately I don't know if they moved or closed up since then.
    You could try your luck at the electronics stores like DEECO or even RGY in V-Mall.
    May 2004
    Meron din sa Farmers. Forgot the name of the stores pero madadaanan mo sya coming from MRT going to gateway.
    Aug 2005
    Thanks for sharing. very nice!
    Use your cigarette lighter interface. Output is 12V,- then put a regulator and set it at 3.6V and solder its terminals to your epass.
    After that,- no more changing of the battery....
    13.9K:mop:
    ^ uy... pwede pero I still need unlimited load...
    meron ako nabasa before nahulog niya epass niya then naging unlimited for a couple of months yata na stock sa P1000 yun load niya kahit hinde na siya nag load.
    Jun 2006
    Went to the Greenhills battery store. They quoted 1500 for the battery. Did not buy. I did open the epass and put it back together. For some reason it now works better than before opening.
    ^told you...almost the same lang magagastos mo kung palitan batt and bumili ng bagong unit
    Jan 2003
    there is still a battery shop in V-mall on 4th floor. pero kung 1500 yung battery bili na laang ako bago.
    just a thought... what if you solder those solar cells from china calculators... para laging charged.... hmmmmm pwede kaya?
    Quote Originally Posted by impulzz View Post
    Hmmm... CDRKING calculators sell for under P80 each.
    Each solar cell is 1.5V,- so not sure how many cells you have to solder to get 3.6V.....
    14.0K:bike3:
    May 2012
    Meron kau makukuha na EPASS BATTERY dyan sa Paranaque sila. They are supplying Original EPASS BATTERY. i got their number 02-9190817 or txt nyo 09199916188
    ^ Di rin halata na nagaadvertise si kuya... :hihihi:
    Quote Originally Posted by SHEN IL
    how much? Para magkaalaman na
    Baka gusto mo rin itanong kung pwede ba i-modify yung EPASS para magkaron ng unlimited load. :hysterical:
    I know it's obviously an ad but I'll let it slide... hehehe
    Kung may sagot, ako din!
epass battery
