Yung Lexing, sa Quiapo lang daw nanggaling. Less than Php2k.
Pero may-FR yung kapatid ko, madami na din daw nito sa St. Francis Square. Mas maganda na porma and mas madami na ata games. Mga Php2k pa din daw.![]()
Yes you can. My AVL ADP 2700XM has mp3 support. The usb is specifically for hooking up portable mp3 players.
Plus although the manual doesn't mention it, it also plays raw mpeg1/mpeg2 video and wma sound files. When I tried playing some wmv files, it played only the audio.
You do want to use faster flash drives (connected via usb) because the older, slower ones causes the video/audio to go out of sync.
Although my AVL has an SD card slot, I have no SD cards at the moment. But as soon as I can find some 4GB ones, I'll try it out.
Otep suggest ko lang buy a player kahit anong brand basta may VGA port. Masarap manuod ng DVD sa projector basta hindi RGB o yung Yellow port ang ilagay... the best ang VGA port!![]()
Yung Xenon merong VGA port. Naisip ko din iyang LCD. hehehe.![]()
doc, na test mo na bang mag play ng divx/xvid files? or reading from dvdrs?
plano ko din kasi bumili ng xenon..
sir otep i saw the unit that u bought s sm...napansin mo ba na ang nkalagay sa face ng unit e "dts digital out" pero sa box niya "dts surround" ang nka print... alin kaya 22o? sbi opismate q mas ok pag "dts surround".
Wala yata ako bala ng DIVX dito (paano ko ba malalaman iyon?). Pero yung DVDR's binasa niya.
Naku, hindi ko lang po sure kung ano pinagkaiba nila. Sana mabigyang linaw din ako ng mga Tsikoteers.napansin mo ba na ang nkalagay sa face ng unit e "dts digital out" pero sa box niya "dts surround" ang nka print... alin kaya 22o?
[quote=OTEP;718761]Wala yata ako bala ng DIVX dito (paano ko ba malalaman iyon?). Pero yung DVDR's binasa niya.
quote]
Just burn a data dvd+/-r/rw with divx movie files in it on your pc. On mine, I just drag and drop with Vista RC1.
A 4.7GB platter should be able to hold 5-7 full-length Divx movies.
My Divx files use the avi container. Hence on screen:
[quote=number001;718784]On a regular 20" crt tv, they look quite good and often hard to tell from the dvd original until the movie hits a black area where I might see a few pixels. I normally render the Divx movies at a res of 512 x 384 for the full-screen ones. On tv, the quality is about as good as a brand new VHS movie and much less pixelated than a vcd/svcd. I'd say it's on par with the movies from DirectTV.
The pixelization showing here would be hard to see on a regular tv......
The ghosting is due to to camera movement on my part. Overall image quality on tv is much better than the tv screencap.
My ultimate goal is to stuff these movies into a portable media center with Divx capability. So, 512 x 384 is a good balance between watching on a tiny screen and a regular tv. File sizes average around 720mb per movie.
Add: Pirates 1 on mine is about 719mb. I used AutoGK to make the Divx files and set the file size to 1 CD.
Regular TV resolution yata is 320 x 200 kaya enough na yung 512 x 384... DVD is 720 x XXX yata hence the 720p HD TVs... tapos sabi nila no noticeable difference sa movies pag 720p, 1080i at 1080p kaya safe bet is to encode using 720p resolution... Kasi pang games lang naman yata mag benefit sa 1080i at 1080p e.... But then again our monitors sa PC, we all use 1024 x 768 resolution right???? so there are really choices & decisions to make... baka safe ang 800 x 600 resolution....![]()
Got our Xenon player before Christmas. Was finally able to test the USB feature last night. So far so good![]()
Took a while to read a 1GB USB drive filled to the gills with DIVX AVIs but it was plain sailing after that. It plays the first track automatically. It displays the directory when Stop is pressed. Only the first 8 characters of the filename are displayed (memories of DOS anyone?) so episode numbers ideally have to be in those first 8 characters.
Got it for slightly less than 3k at Blims GH.
Finally found a format na di kaya ng Lexing ko, Divx. Sayang! Sa player nakamark yung divx. Happy pa rin ako kasi it plays scrathed discs that hang on my laptop and other dvd players.
how do you check what codec it uses? my computer says its .divx is that it?
You can use Divx Player which is part of the free Divx package. Once the movie is playing Alt-I will bring up the file info. I just tried playing a d/l pr0n(used the Divx codec) and it wouldn't play on the dvd player.
All the movie Divx conversions I made work perfectly and they all used the Xvid codec.
Did the Alt I thing on divx player this is what I got:
SC-S1E06.divx
Filename:
D:/SC-S1E06.divx
Video Track #1:
FOURCC: "DX50" (DivX® Video)
512x288, 23,976000 fps
Audio Track #1:
FormatTag : "85" (MPEG-1 Layer-3 Audio (mp3))
2 channels, 44100Hz
Language: N/A
Does this mean that it uses the DX50 codec or DivX codec?
